Detection Log
04/06/2021 at 17:04 • 0 commentsI have analyzed and graphed the collected data logs. The data covers everything within a 300 electron-Watt radius of the device.
there were no aliens detected.
Calibrated
04/06/2021 at 16:22 • 1 comment![]()
device correctly reads 0V when only humans are within the detector field.
6 + 6j spurving vanes
04/06/2021 at 16:20 • 0 comments12 spurving vanes: 6 real, 6 imaginary (not visible in the photos)
Drake Feynman
04/06/2021 at 16:19 • 0 commentsThis is a fairly simple and straightforward implmentation of a Drake-Feynman Alien Detector.
wikipedia has most of the details:
A small Herring
04/06/2021 at 16:18 • 0 commentsAfter interference by the neighbor's cat, the herring needs to be replaced.
Going to try placing it within a sealed vessel below the panatronic fan this time
ebay find!
04/06/2021 at 16:18 • 0 commentsI found a surplus 17 pantagauss feynman spaculume on ebay. This should allow a detection range of nearly 237 Hertz-meters.
jeff
