Introduction
Most electronic systems can be explained using this diagram.
Systems consist of inputs that connect to the outside world, some form of processing or control and outputs to interact with the outside world.
If the system needs multiple inputs (buttons, potentiometers, sensors), you either run out of pins to connect to or you expand your circuit, making it more complex.
Not Enough Pins
As with most microcontroller projects you can quickly run out of pins. Especially analog inputs. A common technique to solve this is to use a multiplexer/demultiplexer. There are analog and digital versions. A common chip that is used is the 4051.
The following is from the Texas Instruments Data Sheet - CD405xB CMOS Single 8-Channel Analog Multiplexer/Demultiplexer with Logic-Level Conversion
“The CD4051B, CD4052B, and CD4053B analog multiplexers are digitally-controlled analog switches having low ON impedance and very low OFF leakage current.”
“The CD4051B device is a single 8-channel multiplexer having three binary control inputs, A, B, and C, and an inhibit input. The three binary signals select 1 of 8 channels to be turned on and connect one of the 8 inputs to the output.”
![]() ![]() NOTE In this example the 4051 is being used to connect multiple inputs to one pin but the 4051 will work in either direction. |
Although I have used 4051 MUX in previous projects, I found that similar problems would occur with each new system I created. I would lose track of what pin on the 4051 mux was connected to the pins on the microcontroller. Each mux needed a set of control pins (C, B, A) and analog input, so I would quickly run out of pins. Plus, I had to totally rebuild the circuit each time I wanted to try something new.
Here is my example synth project again. It worked ok but when I started to work on it again after a few weeks break I struggled to continue with its development due to the circuit’s complexity.
Initial Idea
I had the idea of designing a system that would allow me to add as many MUX circuits as needed without the need to modify the code too much. I could use a bus to carry the signals to and from each MUX card circuit.
The microcontroller connects to each card via the bus(es)
My idea was to make each card have a unique address that the microcontroller could use to enable each card independently.
Each card would require control circuitry to read the address from the microcontroller and enable that cards MUX.
Control Circuitry
Initially I planned to use just three address lines from the microcontroller. This would give me 8 possible addresses for the MUX cards. Each MUX can have 8 inputs so 8 cards x 8 inputs = 64 possible inputs.
| NOTE: The system is designed to allow me to add another address line later if needed. 4 address lines = 16 addresses. 16 cards x 8 inputs = 128 inputs. Also if needed it is possible to put multiple MUX chips at each address giving more inputs or you could use a 16 channel MUX. e.g. a 74HC4067. |
The MUX card needs to control the enable pin of the MUX. To do this it reads the address from the microcontroller. If the address is identical to the cards address, then enable the MUX. If not, then disable the MUX.
The 4051 MUX control pin is called INH (pin 6). A high signal disables the MUX. Therefore, the control circuit needs an output that goes low when the correct address is read.
Here is a block diagram of the address decoder.
I will use a DIP switch x 4 to set the address of the card.
| NOTE The switch is shown upside down as I plan to use pull up resistors. |
Designing the Control Circuitry
The enable...
Andy Birch
SCART VADER
Leon
Hulk
