Thunderbird-68000 SBC @32 MHz
An easy-to-build and easy-to-understand single-board retro computer, perfect for overclocking and running the Fuzix OS (at 32 MHz).
In a previous 68000 minimal homebrew project, I attempted to run Fuzix on the self-built system with only 128kB of SRAM (1991). Unfortunately, it didn't work due to a lack of memory. After some deliberation, I decided to design a new PCB with a MC68HC000 cpu with a lot of memory (1 MB):
- Capable of running the Fuzix OS (https://www.fuzix.org).
- Simple to overclock.
- Easily to understand (no PAL/GAL etc).
- Low current (all CMOS).
- Easily to rebuild (only through hole components).
- And last but not least: KISS (Keep It Simple and Straightforward).
Specifications:
- MC68HC000-FN20.
- 1024 kB RAM (2xAS6C4008-55.)
- 128 kB EEPROM (2xW27C512-45.)
- 16550 UART @ 115200 baud (accessible only in supervisor mode).
- 100 Hz RC-oscillator (for task switching and simple timings).
- IDE interface (for CF-card or SD-to-IDE converter).
- SD-card support.
- All CMOS: low power: 150 mA @20Mhz, 200 mA @32Mhz (=1 W).
- PCB 10x10 cm (4 layers).
Power supply
The power for this board is provided by the USB-to-Serial converter. A 250 mA polyfuse protects against damage in the event of a short circuit. A diode protects against a reversed power supply.
A red LED indicator lights up when power is available. Use a high efficiency LED, because it is powered by a 5KΩ resistor.
Reset circuit
The reset signals are generated simply by a 10µF capacitor, which is charged through a 10k resistor. Two Schmitt trigger inverters (74HC14) are used to generate the positive and negative RESET-signals. Since both the 68000's /RESET and /HALT-signals are bidirectional (input and output), they are connected through a 4.7kΩ resistor.
Address decoding
In fact, the address decoding is arguably the most fascinating aspect of the design!
In the simplest 68000 designs, the EEPROM is fixed at address 0x0000. After a reset, the CPU expects the stack pointer and start address to be located at 0x0000 and 0x0004, respectively. All interrupt vectors are in the next 1kB till 0x03FF. If these vectors are fixed in EEPROM, it limits flexibility, especially when attempting to run the FUZIX OS.
A solution is to switch out the EEPROM and switch in the RAM after the first four read cycles. This is the exact purpose of the 74HC164. After a /RESET, all Q-outputs are initially low. The /AS signal is used as clock, and after four (16-bit) read cycles, the Q3 output goes high.
The 74HC139(a) is connected as an OR-gate (I used this complicated way because I didn't want to add an extra OR-chip and I had one decoder left.) The first four cycles the /E input is high, so all the /Y-outputs are high. The /Y0-ouput is connected to the A1-input of the second (b) address decoder, and thereby switching in the EEPROM in the first four read cycles.
After the four read cycles, the /E signal is low, and /Y0 begins to follow A21. From that point onward, the RAM is mapped to address 0x0000.
CF-card interface
For CF/IDE-card, we need different timings. First the /CS have to be activated, and then the /RD (of /WR). The /RD needs to de be activated before /CS becomes inactive. For EEPROM and RAM these timings are irrelevant, and may be simultaneous.
In the 68k-nano design (by Matt Sarnoff), I found a solution. In typical 68000 address decoding, the /AS-signal from the CPU is connected to the /E-input of the 74HC139 decoder. However, you can bypass the /AS-signal by grounding the /E-input. This causes the /Y0 to /Y3-outputs to become active earlier (before the /RD and /WR-signals). The downside is that one output signal is always active, even when there is no bus activity. I built the 68k-nano, and this works perfectly fine.
So pin 15 (/E-input) is grounded for the correct CF/IDE-card timing.
R/W-signals
The 68000 has a 16-bit bus, and the upper (odd) and lower (even) bytes can be read or written individually. Therfore four signals are required:  /WR_even, /WR_odd, /RD_even and /RD_odd. These can be generated using a 74HC32 (4 OR gates) and an inverter. However, a single 74HC139 can also generate these signals, and I like this design.
As you can see, the /AS (address strobe) signal is also used as enable input. This means that the /RD and /WR  signals only become only active when the /AS is active. In this way, the absence of /AS in the address decoding is compensated.
100Hz oscillator
For task switching and basic timing, a 100 Hz RC oscillator is added. A 100k resistor charges a 100nF capacitor, and the Schmitt trigger generates a clean square wave, which is connected to the RI input of the UART. This generates periodic interrupts.
While the RC combination is not highly precise, the capacitor can be selected to achieve the desired 100 Hz signal.
UART, IO and interrupts
The UART TL16C550 is an excellent chip. It features 2x16-byte receive and transmit...
BIOS-thunderbird.zip
Zip Archive - 48.83 kB - 01/01/2025 at 16:57
Download
68kTunderbird_rev0.zip
Gerberfiles
Zip Archive - 195.65 kB - 01/01/2025 at 15:39
Download
68kThunderbird_rev0.pdf
Schematic
Adobe Portable Document Format - 760.20 kB - 01/01/2025 at 11:28
Preview
  • 1 × MC68HC000-FN20 68000 CPU (PLCC68)
  • 2 × W27C512-45 64kB EEPROM
  • 2 × AS6C4008-55 512 kB SRAM
  • 1 × TL16C550 UART
  • 2 × 74HC139 Address decoder
View all 7 components
  • Overclocking 68000 @32 MHz
    Steven07/13/2025 at 09:01 0 comments
    History
    When I went to high school, we of course had calculators. It became a kind of sport to see which calculator was the fastest. There were two main brands: Casio (FX-82) and Texas Instruments (TI-30). The Casio FX-82 was much faster at calculating factorials than the Texas Instruments models. We used to test them with 69! (= 1 × 2 × 3 × ... × 69), which took a few seconds to compute.
    When I opened the FX-82 calculator, I discovered a resistor inside. Adding a parallel resistor, which reduced the total resistance—and the calculator ran faster! Apparently, the clock was controlled by a simple R/C (resistor-capacitor) combination. Nevertheless, it was my first overclocking experiment.
    My first computer was an IBM-compatible XT, running at 8 MHz. Internally, there was a 24 MHz crystal, divided by 3 to produce the system clock. I desoldered the crystal and replaced it with a common 27 MHz one. From that point on, the computer ran at 9 MHz! The 12.5% speed increase was measurable, but hardly noticeable in practice.
    Overclocking self build retro systems
    Most CPUs can be overclocked, which means they can run (much) faster than their printed maximum speed. In my experience, an overclock of at least 50% is often possible. However, for various reasons, most self-built retro systems stick to the recommended CPU speed—including mine.
    But if your system runs stably at the advised speed, why not try pushing it further? For example, the 68000 minimal homebrew computer from 1993 was designed to run at 8 MHz, but it could be overclocked to 20 MHz—that's 2.5 times faster!
    The only change I made was replacing the MC68000-P10 (NMOS) CPU with the CMOS version, the MC68HC000-P10 (and of course the oscillator circuit).
    Design considerations
    To push the Thunderbird SBC to its limits, I made the following design decisions:
    • CPU: CMOS versions of the 68000 (MC68HC000) are faster (and consume far less power) than their NMOS counterparts. I also chose for the highest available speed grade—the fastest 68000 is the MC68HC000-FN20, which runs at 20 MHz.
    • RAM: Although faster memory exists, I used the common AS6C4008-55 SRAM chips with an access time of 55 ns.
    • ROM: Most EEPROMs are slower than SRAM, but the (now obsolete) W27C512-45, with an access time of only 45  ns, is actually faster.
    • UART: The TL16C550 is my favorite UART chip. It includes a 16-byte FIFO buffer and offers a few extra I/O pins. I added an 11.0592 MHz crystal, so the serial communication speed remains independent of the main system clock.
    • Clock: The crystal oscillator is mounted in a socket, allowing for easy replacement.
    Conclusion
    After thoroughly testing the system, it runs stably at the astonishing speed of 32 MHz—that's 60% faster than the original 20 MHz. I believe the UART is the slowest component; perhaps adding wait states for I/O could allow the system to run even faster. However, that would also make the design more complex.
  • CF/IDE-interface
    Steven03/02/2025 at 15:38 0 comments
    Introduction
    In homebrew retro computing, the CompactFlash (CF) card is very popular, but SD cards are also used. In Thunderbird, both can be used.
    CF/IDE-interface (44 pin)
    • Easy to connect: The CF card uses the well-known IDE interface, meaning it can be connected directly to the 8- or 16-bit bus.
    • Fast: It is fast due to the IDE interface. After issuing a few simple commands to read a sector, the BIOS only needs to read 512 bytes from the IO-port (Z80) or memory (68000).
    • Obsolete: CF cards are no longer widely used, but they can still be easily ordered online.
    SD-card (SPI)
    • Widely used: Despite its limitations, the SD card remains widely used.
    • Easy to connect: Although the SD card operates at 3.3V, most adapters include a voltage converter/level shifter to 5V. Because of the SPI interface, only four GPIO lines are needed (COPI, CIPO, CLK and CS). In the Thunderbird design, the spare input and output lines from the serial chip (TL16C550) are used for that task.
    • Terribly slow: In homebrew retro computers, there is usually no dedicated SPI interface. It can be simulated via bit-banging, but this is very, very slow (about 10–25 KB/s). However, this is comparable to the speed of an old-school floppy disk. In Fuzix, it gives the feeling of an old timesharing Unix machine—every command takes its time to execute, but in the end, it works well.
    SD-to-IDE converter (44 pin)
    On the internet, there are inexpensive ($10) SD-to-IDE converters. These tiny boards accept either a full-size or microSD card and feature a 44-pin IDE interface. This fits perfectly into the Thunderbird design! I tested it on the board, and it worked flawlessly. The interface supports both 16-bit and 8-bit modes, with the latter being ideal for Z80 or 6502 designs.
    Micro SD to 2.5 44pin IDE Adapter Reader TF CARD to ide For Laptop -  Newegg.com
    CF-card
    (44 pin)
    SD to IDE interface (44 pin)SD-card
    (with interface)
    Voltage:5 V5 V3.3 V (5 V with interface)
    Total system power (@20MHz):200 mA190 mA?? mA
    Interface:8/16 bits to databus8/16 bits to databusSPI ("bit bang")
    Read (sequential):700 KB/s800 KB/s10~25 KB/s (educated guess)
    Read (random):525 KB/s550 KB/s10~25 KB/s (educated guess)
    Conclusion
    For me, the SD-to-IDE converter is a winner. Although there is a slight speed difference between the CF card and the SD-to-IDE interface, their speeds are approximately the same. However, since SD cards are more common, I prefer the SD-to-IDE interface.
  • Bugs & improvements
    Steven02/23/2025 at 18:25 0 comments
    Introduction
    In this log, bugs and potential improvements for the Thunderbird system are described. Fortunately, only minor bugs have been found so far.
    Bugs
    • The CF/IDE busy indicator LED is operating in reverse. When a CF/IDE adapter is inserted, the LED lights up immediately, and when the device is busy, the LED turns off.
    Potential improvements
    • The Thunderbird system, with the CF card running at full speed, draws almost 240mA. Therefore, it is advisable to use a larger polyfuse of 350mA or 500mA instead of the 250mA fuse.
    • When reading a word from the IDE/CF card, the bytes must be swapped due to the little-endian/big-endian difference. This requires extra instructions, but a slight improvement can be achieved by handling it in hardware. Simply swap the low and high data lines at the CF/IDE interface.
View all 3 project logs
Steven wrote 02/06/2025 at 18:10 point
Hi Soni, the SBC only draws about 100mA, so powering by a power bank is no problem. I have no intention to add a dedicated keyboard or screen to it. The whole idea is KISS; keep it simple. I use a macbook as “terminal”.  (Sometimes I use it on the kitchentable-off grid). You could use any (cheap) laptop / chromebook as a terminal, and powered by a USB232 it is “mobile” ;-)
soni wrote 02/05/2025 at 19:37 point
Is possible make it mobility? Keyboard, power, screen?
