Hand EKG heart beat detection
05/25/2021 at 00:34 • 0 commentsThis is a demo of heartbeat detection from hand EKG with the help of BioAmp EXG Pill, Arduino Nano, and HeartBeatDetection.ino code.
Chest ECG heart beat detection
05/25/2021 at 00:31 • 0 commentsThis is a demo of heartbeat detection from chest ECG with the help of BioAmp EXG Pill, Arduino Nano, and HeartBeatDetection.ino code.
Servo control
05/23/2021 at 21:26 • 0 commentsArduino sketch for controlling a servo motor with EMG has been added.
LED Bar graph
05/23/2021 at 06:43 • 0 commentsArduino sketch to show EMG potential on an LED Bar graph has been added.
EMG Envelop detection
05/16/2021 at 00:50 • 0 commentsAn envelope detector is a sophisticated algorithm that takes a (relatively) high-frequency amplitude modulated signal as input and provides an output, which is the demodulated envelope of the original signal. To use the EMG signal sampled by the ADC in a useful manner we need to detect an envelope of the signal recorded. A standalone Arduino code EMGEnvelop.ino has been added to the EXG repository which can be used for things like an LED bar graph of EMG potential and Servo control.
EMG Filter Arduino code
05/13/2021 at 04:45 • 0 commentsA development-board independent EMG Filter Arduino code has been added to the BioAmp EXG Pill Github repository. The frequency response plot of the band-pass filter implemented and image of recorded EMG is attached below.
ECG Filter Arduino code
05/02/2021 at 11:10 • 0 commentsA development-board independent ECG Filter Arduino code has been added to the BioAmp EXG Pill Github repository. The frequency response plot of the band-pass filter implemented and image of recorded ECG is attached below.
Fixed Sampling Arduino program
05/01/2021 at 13:02 • 0 commentsDifferent BioPotential signals (ECG, EMG, EOG, and EEG) contain information in different frequency bands and require a minimum sampling rate to not lose any valuable data.
FixedSampling Arduino code allows you to set a fixed sampling rate for your Arduino-compatible board's ADC input. Fixed sampling also helps in applying digital filters onto the signal recorded as you are required to have a fixed sampling rate for that.
ECG, EMG, and EOG
04/14/2021 at 22:13 • 0 comments -
EOG visualization
04/14/2021 at 22:12 • 0 comments
Deepak Khatri
