Oh damnit, forget about Pisano16x2.v2.c and test_Pisano16x2.v2.c because I just found a stupid off-by-one error!
Anyway, here is the old version.
___________________________________
I just modified the "reference code" for the checksum algorithm by "early-mixing" the size of the buffer. This helps in the case of comparing two blocks (or files) with a checksum collision: the metadata of the block size will help telling them apart.
I also added guidelines for the initial value, considering the worst case of input data:
- odd values should set the LSB from the start
- high values wrap around sooner.
Hence I have chosen 0xABCD in the reference code.
#define PISANO_WIDTH (16) // Do NOT change.
#define PISANO_SIZE (1<<PISANO_WIDTH)
#define PISANO_MASK (PISANO_SIZE-1)
#define MAGIC_INIT ( 0xABCD ) // do not use 0 or FFFF.
// Odd, high values (> 30K) are better for early avalanche.
uint32_t Pisano_Checksum32(
uint16_t *buffer, // points to the data to scan
int size // number of 16-bit WORDS to scan
) { uint32_t
// Init
X = *buffer ^ (size >> 16),
Y = MAGIC_INIT + (size & 0xFFFF),
C = 1;
// Loop
while (size) {
C += X + Y;
X = Y ^ *buffer;
buffer++;
Y = C & PISANO_MASK;
C = C >> PISANO_WIDTH;
size--;
// Finish
return (uint32_t)(C+Y+(X << PISANO_WIDTH));
As a result, the generated values for checksumming empty buffers are:
n PEAC16 PEAC32
1: 579D ABCEABCF
2: 0370 ABD057A0
3: 5B15 57A10374
4: 5E90 03765B1A
5: B9B7 5B1F5E98
6: 1864 5EA0B9C4
7: D24B B9D1187A
8: EAFB 188ED26D
9: BDC1 D28FEB32
10: A984 EB69BE1B
11: 6888 BE73AA15
12: 1416 AAA46972
13: 7FEA 6A5A1590
14: 9954 1708824C
15: 21DD 84AE9D2F
16: C925 A10A281B
17: 0194 2E57D33D
18: EF3F DD5511EA
19: 2BEB 223E09AD
20: 7AC6 241956AD
21: 4164 816FBFF5
22: B67A 0524B156
23: 8CE2 21476B9B
24: D2AF 20BBB1F4
25: 83E7 D705ACE2
26: 0A3F 8713832C
27: 6624 826FE3B5
28: FC0A BD2B3EDF
29: C5D2 1798AE3A
30: B126 606950BD
31: C9E5 DBA6EE3F
It looks pretty well behaved, particularly if you compare with the standard Fletcher/Adler.
For now the reference code uses XOR mixing and the debate is not yet settled if the ADD mixing method is more robust.
Anyway this new version looks more adapted than the previous one for the comparison of files, for example (as long as you can mmap() them because I have not yet implemented a system for multi-part checksums).
