PEAC Pisano with End-Around Carry algorithm
Add X to Y and Y to X, says the song. And carry on.
A purely additive, non-cryptographic, fast and minimalistic checksum/PRNG/scrambler.
The sweet spot is a 32-bit checksum with a pair of 16-bit registers,
- very small, using only ADD,
- without the flaws of Adler32 and Fletcher, yet the same size and complexity,
- as good as CRC32, which it may replace when the memory footprint is critical
- can't be 0-crashed
- very easy to implement in digital circuits as well as microcontrollers,
- suitable for the detection of trivial corruption in network packets or files.
- not patented
- "as is", inappropriate for cryptography (though could inspire someone)
Lately, gPEAC with m=741454 (39 bits of entropy) has been found, a bit slower but with better avalanche than the PEAC with w16, more suitable for hash tables.
French article in GNU/Linux Magazine France
If you wonder why, just click and read the log.
For the what, check Definitions and Draft as well as PEAC vs LFSR for a comparison.
The original algo/project name was "Fibonacci checksum" but it later appeared that it was not the most accurate choice because Leonardo Pisano (the real name of Fibonacci) is the name associated to the periodicity of the sequence under modulo. All I did was add the tiny detail of "end-around carry", or "1-complement addition", which changed everything.
-o-O-0-O-o-
As for how I came to this system...
In 2012, Piano Magic released their album "Life Has Not Finished with Me Yet". One song contains a weird repeating pattern...
Glen Johnson's lyrics are often cryptic and more evocative than objective, but any geek's mind would cling on this mantra at the end:
"Add X to Y and Y to X"
This is really weird but... Why ? What's the point in this obscure "song" with no precise theme or clear subject ? And what does it do ? This last question is the most easily answered : just follow the damned algorithm.
C'est parti...
X=1, Y=0
Y+=X => 0+1=1
X+=Y => 1+1=2
Y+=X => 1+2=3
X+=Y => 2+3=5
Y+=X => 3+5=8
X+=Y => 5+8=13
X+=Y => 8+13=21
Y+=X => 13+21=34
X+=Y => 21+34=55
No need to go further, most of you should have recognised http://oeis.org/A000045, the famous Fibonacci sequence.
This gave me a compelling idea to modify the old Fletcher & Adler algorithms, keeping their very low footprint and minimalistic computational complexity. Both of these well known algos use a pair of values and have a similar structure. The trick is that rearranging the data dependency graph provides the equivalent of a minimalistic polynomial checksum, because the result is fed back on itself, in a more robust way than Fletcher's algo.
At first glance, this new checksum loop's body becomes something like :
Y += ( X + datum[i  ] );
X += ( Y + datum[i+1] );
i+=2;
This loop body is totally trivial to unroll. As trivial is the design of the corresponding digital circuit. This early version seemed to contain the whole checksum entropy in the last computed value but now X and Y are part of the signature. And the really important enhancement is the use of the carry!
For superscalar 32 bits CPUs, the following code seems to work well though the missing carry hardware (and/or lack of language support) requires more instructions to emulate:
t = X + Y + C;    Y = X + data;
C = t >> 16;      X = t & 0xFFFF;
A more efficient variation exists which does not use a temporary variable:
C += X + Y;
Y = X + data;
X = C & MASK;
C = C >> WIDTH;
In this worst case, without support of a carry flag, that's 5 basic operations (not counting memory loads) that fit in 4 registers and 3 cycles, to process 2 bytes. Not too bad. I'll let you deal with alignment. But is it really safe or safer?
The following logs will show how the idea evolves and the performance increases, through discussions about carry wrap-around, register widths, scheduling, avalanche, parallelism, orbits, structure, and escaping black holes...
-o-O-0-O-o-
Logs:
1. The variable
2. Datapath
3. Adler32 weakness
4. Easy circuit
5. Periodicity
6. A promising 32-bit checksum
7. Progress
8. Why
9. Orbital mechanics
10. Orbits, trajectories and that damned carry bit
11. Two hairy orbits
12. How to deal with black holes
13. Anteriority
14. Moonlighting as a PRNG
15. A new name
16. More orbits !
17. First image
18. Structure and extrapolations
19. Even more orbits !
20. Start and stop
21. Some theory
22. Some more theory
23. Even more theory.
24. A little enhancement
25. sdrawkcab gnioG
26. Further theorising
27. What is it ?
28. A bigger enhancement
29. Going both ways
30. Can you add states ?
31. Please, GCC !
32. _|_||_||_|______|______|____|_|___|_________|||_|__
33. Carry on with GCC
34. A good compromise
35. The new non-masking algorithm
36. Add or XOR ?
37. A 32/64-bit version
38. Closing the trajectories
39....
gPEAC.000002-1000615.perfect.txt.gz
25072 perfect moduli from 2 to 1000538
gzip - 60.47 kB - 11/12/2025 at 07:18
Download
gPEAC.000002-1000615.maximal.txt.gz
62570 maximal moduli from 3 to 1000583
gzip - 153.11 kB - 11/12/2025 at 07:15
Download
ygrand.tgz
a POSIX-conformant replacement for rand() and srand(). Also provides a "fake" generator (pulling data from /dev/random) to help with statistical comparisons.
x-compressed-tar - 1.81 kB - 02/10/2025 at 03:43
Download
Checksum_PEAC64_asm.c
64-bit checksum, 7 instructions and 128 bits per iteration, in asm for x86-64
x-csrc - 2.73 kB - 11/04/2024 at 06:34
Download
PEACLS_20241013-2.tgz
PEACLS : scrambler and descrambler finished, detect errors
x-compressed-tar - 20.95 kB - 10/13/2024 at 20:11
Download
View all 73 files
  • PEAC w18
    Yann Guidon / YGDES • 12/29/2025 at 20:08 • 0 comments
    The last log of #miniMAC - Not an Ethernet Transceiver  had concluded that the association of two convolutional blocks of different types but complementary characteristics creates an excellent error detector, on top of thorough scrambling. But the use of a gPEAC becomes dubious, it was used for two reasons:
    • PEAC w18 is not known for being perfect or maximal
    • PEAC w18 has poor mixing, a generalised type is better.
    However it was found that
    • gPEAC18 uses 2 cycles instead of one, reducing the throughput
    • the added NRZ-Hamming preprocessing totally solves the mixing issue
    • It is probably not necessary to beeven close to maximal.
    So PEAC w18 is back in the race to reduce the latency and gates count. But I realise that I know almost nothing about it !
    I looked back at the logs and found quite little.
    • 19. Even more orbits ! : primary orbit of 18 : 172.662.654  (instead of 34.359.738.368 to pass, or 0.5%)
    • 44. Test jobs :     18: Total of all reachable arcs: 68719736689
    • 90. Post-processing : Width=18 Total= 34359868344 vs 34359869438 (missing 1094)
    The missing iterations hint at a small "island" that can't be reached from Y=0 and that's a bit worrying.
    I don't know the number and sizes of the other orbits. Fortunately I could reuse fusion_20220109.tgz and the logs logs_p7k_03-21.tbz.
    • 11 orbits of length 15,696,605
    • 198 orbits of length 172,662,655
    In practice, it is not plausible to send 15 million words with the same value.
    But the nature of the 1094 missing points is still disturbing and I'll have to program it out. And I only have 32GB of RAM at best, so the 67 billion points can't be represented as bytes. I'll have to do with bits. Filling the RAM with the 198+11 orbits should not be a problem since I have their coordinates, then I'll see which bits are untouched. A few kilopoints should not be hard to process then.
  • gPEAC-LEA19
    Yann Guidon / YGDES • 11/29/2025 at 11:04 • 0 comments
    The modulus 741454 is excellent but it can be made more so.
    Log 172. Hashing with PEAC39/2 has great info but let's consider something else: the LEAQ opcode on x86-64. This can compute something like x = y + (z×8) + const in a single cycle.
    Which is awesome because if we have x using 16 bits, the ×8 does a <<3 and x  now gets 19 bits.
    In fact 65535×9=589815 < 741454
    741454 - 589815 = 151639 > 2^17
    So the constant/offset is smaller now and the avalanche is much better because the input will affect the MSB sooner.
    There is not even a need to select a prime number since it wouldn't change the orbit length when x=0. A bit pattern like 0x17777 (=96119) works just as well.
  • Discrete PEAC
    Yann Guidon / YGDES • 04/19/2025 at 13:21 • 0 comments
    Reading old logs, I rediscovered 1. Notes on using a pipelined ALU for frequency division and it appears that I could build a discrete PEAC16×2 using a pair of circuits I have somewhere in stock.
    These adders could work in parallel, with a fixed configuration, and though I doubt they could run at the advertised 40MHz, it's fast enough to implement the scrambler of #Not an Ethernet Transceiver.
    I just need to find where I have stored the chips...
    Of course a FPGA will be faster and more practical but I know some people still prefer discretes and MSI :-D
  • Stutter
    Yann Guidon / YGDES • 02/11/2025 at 11:38 • 0 comments
    Playing a bit with PEAC w4 :
    #include <stdint.h>
    uint8_t PEAC_XC=1,  // the 5-bit part
            PEAC_Y=0;   // 4-bit
    #include <stdio.h>
    int main() {
      int i=0;
      do {
        printf("% 3d:   % 3d  % 3d \n", i, PEAC_XC, PEAC_Y);
        // split
        uint8_t PEAC_X = PEAC_XC & 15;
        PEAC_XC >>= 4;
        // PEAC scrambler
        PEAC_XC +=   PEAC_X + PEAC_Y;
        PEAC_Y   = ( PEAC_X + 0 ) & 15;
        i++;
      } while (i <= 136);
      return 0;
    W4 is a maximal, not perfect, orbit so there are "only" 135 iterations. But the output sequence, either PEAC_Y or PEAC_XC, shows that some numbers repeat but only in consecutive pairs
            XC    Y
      0:     1    0
      1:     1    1
      2:     2    1
      3:     3    2
      4:     5    3
      5:     8    5
      6:    13    8
      7:    21   13
      8:    19    5
      9:     9    3
     10:    12    9
     11:    21   12
     12:    18    5
     13:     8    2
     14:    10    8
     15:    18   10
     16:    13    2
     17:    15   13
     18:    28   15
     19:    28   12
     20:    25   12
     21:    22    9
     22:    16    6
     23:     7    0
     24:     7    7
     25:    14    7
     26:    21   14
     27:    20    5
     28:    10    4
     29:    14   10
     30:    24   14
     31:    23    8
     32:    16    7
     33:     8    0
     34:     8    8
     35:    16    8
     36:     9    0
     37:     9    9
     38:    18    9
     39:    12    2
     40:    14   12
    This "stutter" might be a sort of "signature" of a PEAC PRNG, which is why PEAC is better used as a scrambler IMHO.
    Now, is this "stutter" a defect ? Not really. On the primary orbit of w4 above,
    •  the number 2 appears 11 times and "stutters" 2 times.
    •  3 appears 9 times and stutters 1×.
    • 4 appears 12 times and stutters 1×
    So in a maximal (and not perfect) orbit, there are some imbalances.
  • Init vectors
    Yann Guidon / YGDES • 02/08/2025 at 14:34 • 0 comments
    Until now I use 0xABCD and 0x4567 to initialise the PEAC16x2 algorithms, but they don't propagate the carries enough. This comes from the fact that even and odd hex digits are "aligned" so there are at least 4 bits that are identical at each position. Ideally : X|Y=1 for each bit position.
    One way to solve this is to offset the digits by one position : X=0xBCDE and Y=0x4567
    This is slightly better:
    >>> hex( 0xABCD | 0x4567 )
    '0xefef'
    >>> hex( 0xBCDE | 0x4567 )
    '0xfdff'
    Time to update all the other references...
  • a POSIXy rand()
    Yann Guidon / YGDES • 02/07/2025 at 18:09 • 0 comments
    After the last log, here's a first draft of a POSIX-compliant PRNG to replace the dumb congruential generator. The combined period should exceed 2^64 yet no heavy operation (like multiplies or moduli) are used. Of course I should test the quality of the output...
    #include <stdint.h>
    #define RAND_MAX 32767
    /* From the spec: If rand() is called before any calls
       to srand() are made, the same sequence shall
       be generated as when srand() is first called
       with a seed value of 1. */
    uint32_t rand_LFSR    =  1,
             rand_PEAC_XC =  1;
    uint16_t rand_PEAC_Y  =  0;
    void srand(unsigned seed) {
      if (seed) rand_LFSR = seed;
          else  rand_LFSR = 0x89ABCDEFUL;
      rand_PEAC_XC  =  seed;
      rand_PEAC_Y   = ~seed & 1;
    int rand(void) {
      // LFSR PRNG :
      uint32_t t = rand_LFSR & 1;
      rand_LFSR >>= 1;
      if (t)
        rand_LFSR ^= 0x82608EDB; // CRC32 poly
      // PEAC scrambler :
      uint16_t rand_X = rand_PEAC_XC; // 16 LSB
      rand_PEAC_XC = (rand_PEAC_XC >> 16)
                   + rand_X + rand_PEAC_Y;
      rand_PEAC_Y  = rand_X + rand_LFSR; // 16 LSB
      return rand_PEAC_XC & RAND_MAX;
    Let's see how far this one flies.
    The first compile and run go smoothly:
    [yg@ygrand]$ gcc -Wall -Os -o test_ygrand test_ygrand.c  && ./test_ygrand
    0000000000000001
    0000111011011101
    0101100010010100
    0100110001001101
    0110000110011000
    0000110001000000
    0000111111001111
    0110110100001010
    0110001101111111
    0100001111011101
    0001111011001111
    0001111001100110
    0101000000111101
    0011010111111011
    0010100111100101
    0111000110110111
    0110010010000111
    0000000011101101
    0011101011001100
    0010000000101001
    0100110100101110
    0110011001110011
    The PRNG is not even initialised, only using the default value of 1, and it immediately reached a high scrambling state. Calling srand() is a must though, and should call rand() a few times itself for "better results".
    Initialising with srand(0) also gives a good-looking sequence with the help of some extra calls to rand().
    The Hamming distance between consecutive numbers looks good after 10000000000 iterations. Note that slot 16 is cleared because only 15 bits are provided at each step.
      0 : 305938
      1 : 4575646
      2 : 32047057
      3 : 138854426
      4 : 416575520
      5 : 916453074
      6 : 1527396508
      7 : 1963876973
      8 : 1963793753
      9 : 1527393214
     10 : 916423856
     11 : 416545995
     12 : 138835287
     13 : 32036947
     14 : 4580472
     15 : 305334
     16 : 0
    The peak is well centered around slots 7 and 8, the histogram is nicely symmetrical.
    For comparison, I made a "fake PRNG" that pulls data out of /dev/random and here is the histogram:
      0 : 305586d
      1 : 4579839d
      2 : 32047565d
      3 : 138857968d
      4 : 416545970d
      5 : 916470025d
      6 : 1527349897d
      7 : 1963799989d
      8 : 1963842436d
      9 : 1527391622d
     10 : 916495473d
     11 : 416539621d
     12 : 138850583d
     13 : 32042754d
     14 : 4575830d
     15 : 304842d
     16 : 0d
    It's pretty spot on but that's only one of many aspects to check.
    ___________________________________________________
    Update : I fixed the init values so it matches srand(1) after 3 calls to rand().
    uint32_t rand_LFSR    =  0x61A864DB,
             rand_PEAC_XC =  0x00015894;
    uint16_t rand_PEAC_Y  =  0xF3B8;
    I've put the files there  ygrand.tgz
  • a rand()... or so.
    Yann Guidon / YGDES • 02/03/2025 at 15:11 • 0 comments
    I have recently received inquiries from two projects :
    • Defora (anything at this point is better than this)
    • TrapC (in need of a good library/implementation)
    Both are interested by a new/better implementation of the rand() function and it would be beneficial to merge these two requests.
    First, I need a good definition of the requirements : size of the state, width of the registers... I'll first try a typical version with two variables, not much larger than the historic implementation (congruential generators have only one register). I suppose that the variable seed must be adapted...
    Already, a limitation : POSIX defines rand() as returning an int limited by RAND_MAX>=32767
    The <stdlib.h> header shall define the following macros which shall expand
     to integer constant expressions:
    {RAND_MAX}
        Maximum value returned by rand(); at least 32767.
    On my local installation, /usr/include/stdlib.h says
    /* The largest number rand will return (same as INT_MAX).  */
    #define RAND_MAX        2147483647
    (Note: yet another reason that POSIX IS DEAD ! You CAN'T know your local size until you test the system, instead of being sure to have a certain width that lets you program comfortably everywhere).
    Now, the recent libc has more than one function :
    void          srand(unsigned);
    void          srand48(long);
    void          srandom(unsigned);
    int           rand(void);
    int           rand_r(unsigned *);
    long          jrand48(unsigned short [3]);
    long          lrand48(void);
    long          mrand48(void);
    long          nrand48(unsigned short [3]);
    long          random(void);
    double        drand48(void);
    double        erand48(unsigned short [3]);
    So it's a whole crazy mess... and https://pubs.opengroup.org/onlinepubs/9699919799/functions/srand.html adds more mess. But who uses it anyway ?
    For TrapC,
    We need
    • a crypto random for crypto stuff,
    • a streaming random for telecom stuff,
    • a repeatable random for scientific stuff,
    • and a good checksum hash that isn't random for hash tables...
         crypto_random_t cr;// for casino real-money gaming
         packet_random_t sr;// for encrypted streaming transmission
         pseudo_random_t rr("test 1");// for repeatable A/B testing
         hash32_t h32("hello world");
         hash64_t h64("hello world");
    And constructors to automatically do the right thing to seed generators. An application programmer doesn't need to know how they work to use them.
    Let's go back to POSIX.
  • Checksum w16 on 6309
    Yann Guidon / YGDES • 02/02/2025 at 01:02 • 0 comments
    My friend François designed a SBC sporting a Hitachi 6309E, a faster and extended version of the venerable Motorola 6809. Looking at its instruction set table, I find that it has instructions that handle 16 bits at once on the D register (made of the A and B byte accumulators). This is actually pretty suitable for a PEAC16×2 algorithm, which is way better than the xorsum currently used...
    But François said :
    • the program must use the LEAST number of bytes
    • the checksum is reduced down to one byte
    • the scanning range can be from one to 2^16 bytes.
    PEAC16×2 works with pairs of bytes so the eventual extra odd byte must be handled separately at the end. And there is no notion of alignment, but the 6809 is a Big Endian machine. Since the constraint is placed on the code size and not the speed, the algorithm loop would work on individual bytes, not 16-bit words.
    At first look, the algorithm is more complex and larger than xorsum but a first enhancement would replace the xor with add, and reuse the carry: this is not foolproof but requires very little effort to implement.
    Replacing xor8 with adc8 divides the error rate by two :
  • PEAC modulo
    Yann Guidon / YGDES • 11/05/2024 at 13:43 • 0 comments
    The log 122. Funky modulo has some funny/funky/hackmemesque observations for lower-level implementations, but what about the higher level ?
    It only occured to me today, thinking about gPEAC, that the wraparound of the sum S goes like
    S' = (S / m) + (S % m)
    Not sure how it's going to help with analysing the large-scale behaviour though, it's above my pay grade.
  • Hashing with PEAC39/2
    Yann Guidon / YGDES • 11/04/2024 at 06:02 • 0 comments
    Look at the logs
    155. More candidates and 741454
    156. The good numbers
    163. Hash enhancements
    The scan has harvested a very interesting number:
    • m= 2^(39/2)-1 = 741454 = 2×7×211×251 = 10110101000001001110b is known perfect, using 20-bit registers.
    • orbit = 549.754.775.568 = 111111111111111111100000010100000010000 in binary, takes about 8 minutes to scan.
    • offset: o = 0111.11010101.11010101 = 7D5D5h = 513493 = 107×4799
    With these parameters, we get a very effective hash algorithm for text strings, 2 bytes at a time (among others). Aside from the PEAC structure itself and its Fibonacci/Pisano scrambling with the addition,
    • The modulus is conditional and increases the scrambling by seeding avalanche with 8 more bits,
    • The offset is unconditional and increases the avalanche in normal ASCII characters, while also triggering "End Around Carry" much more often than normally with empty input.
    TODO
    • Check common divisors of 741454 | 513493 : none !
    • Check the orbit length of PRNG with offset 513493
    For this, the "scanner" must be modified to add the offset, which creates all kinds of ... hmmm algorithmic questions. Fortunately there are two ways to design a checksum with PEAC : single-carry or dual-carry. Single-carry is less parallel but uses a bit fewer operations. It's easy to adapt with the binary PEAC but I realise it's the first time I do this operation on a gPEAC: it's my first gPEAC checksum.
View all 181 project logs
Yann Guidon / YGDES wrote 09/21/2022 at 17:14 • point
https://www.youtube.com/watch?v=EWgts6EiJA0 has some relevant ideas here and there :-)
Yann Guidon / YGDES wrote 07/28/2022 at 16:03 • point
TODO : check the distribution and periodicity of each rank of bit to show they don't exhibit the flaws of https://en.wikipedia.org/wiki/Linear_congruential_generator#m_a_power_of_2,_c_=_0
Yann Guidon / YGDES wrote 04/08/2022 at 11:41 • point
https://en.wikipedia.org/wiki/Cyclic_code
It seems that PEAC is a cyclic code (in a loose way because it's not using Galois fields but still interesting)
Ezra Wolf wrote 01/21/2022 at 23:18 • point
Wow !
Yann Guidon / YGDES wrote 01/26/2022 at 05:27 • point
Hi Ezra, feel free to elaborate :-)
Yann Guidon / YGDES wrote 01/17/2022 at 08:49 • point
Correction to some of my statements here and there (and my videos) : φ is not transcendental but an irrational number that is a solution to the quadratic equation x² − x − 1 = 0. Mea culpa, but at least I learned something from one of the Bogdanoff brothers' countless errors and confusions :-D
Yann Guidon / YGDES wrote 01/14/2022 at 16:55 • point
Oh my !
https://en.wikichip.org/wiki/x86/adx
Now, THAT's a hack :-)
And I can see how it could increase the speed of some algorithms, even this one...
Tim wrote 01/14/2022 at 19:44 • point
On ever other architecture, yes. On x86 is does not add notably to the entropy :)
Yann Guidon / YGDES wrote 01/15/2022 at 12:04 • point
Yann Guidon / YGDES wrote 10/23/2021 at 21:33 • point
Interesting !
https://research.nccgroup.com/2021/10/15/cracking-random-number-generators-using-machine-learning-part-1-xorshift128/
https://research.nccgroup.com/2021/10/18/cracking-random-number-generators-using-machine-learning-part-2-mersenne-twister/
[deleted]
Yann Guidon / YGDES wrote 10/13/2021 at 14:39 • point
so far, half a year and 50£.
Yann Guidon / YGDES wrote 09/14/2021 at 04:16 • point
George Marsaglia and Arif Zaman got quite a lot figured out in 1991:
https://projecteuclid.org/download/pdf_1/euclid.aoap/1177005878
Why didn't this catch up, but they focus on extremely large sequences with tens of registers of lag, and didn't look enough at just a pair of registers. They also didn't look at the link with checksums.
Yann Guidon / YGDES wrote 09/08/2021 at 07:28 • point
Funny !
https://en.wikipedia.org/wiki/Lagged_Fibonacci_generator
Toward a universal random number generator, G.Marsaglia, A.Zaman
Yann Guidon / YGDES wrote 08/05/2021 at 23:24 • point
https://www.researchgate.net/profile/Michael_Greenwald/publication/3334567_Performance_of_checksums_and_CRCs_over_real_data/links/53f4b15f0cf2888a749113c5/Performance-of-checksums-and-CRCs-over-real-data.pdf
"In practice, TCP trailer sums outperform even Fletcher header sums."
Ouch.
Yann Guidon / YGDES wrote 08/08/2021 at 00:51 • point
"Ones complement (with EAC) Fletcher, however, has a weakness that sometimes offsets its probabilistic advantage: since bytes containing either 255 or 0 are considered identical by the checksum, certain common pathological cases cause total failure of Fletcher-255."
Re-ouch.
Yann Guidon / YGDES wrote 08/05/2021 at 23:09 • point
http://users-tima.imag.fr/cdsi/guyot/Cours/Oparithm/english/Modulo.htm and others say that special adders exist to compute mod 2^n-1.
But this is not necessary because the carry is explicitly integrated in the next cycle.
Yann Guidon / YGDES wrote 08/05/2021 at 22:20 • point
https://www.cs.auckland.ac.nz/compsci314s1t/resources/Checksums.pdf  is a nice beginner-level overview of error detection basics. Polynomial checks are mentioned, as well as 1s complement / end-around-carry and Fletcher is well explained but no sight of Fibonacci.
Yann Guidon / YGDES wrote 05/24/2021 at 03:52 • point
Oh, nice !
https://gcc.gnu.org/onlinedocs/gcc/Integer-Overflow-Builtins.html#Integer-Overflow-Builtins
