gPEAC.000002-1000615.perfect.txt.gz
25072 perfect moduli from 2 to 1000538
gzip -
60.47 kB -
11/12/2025 at 07:18
Download
gPEAC.000002-1000615.maximal.txt.gz
62570 maximal moduli from 3 to 1000583
gzip -
153.11 kB -
11/12/2025 at 07:15
Download
ygrand.tgz
a POSIX-conformant replacement for rand() and srand(). Also provides a "fake" generator (pulling data from /dev/random) to help with statistical comparisons.
x-compressed-tar -
1.81 kB -
02/10/2025 at 03:43
Download
Checksum_PEAC64_asm.c
64-bit checksum, 7 instructions and 128 bits per iteration, in asm for x86-64
x-csrc -
2.73 kB -
11/04/2024 at 06:34
Download
PEACLS_20241013-2.tgz
PEACLS : scrambler and descrambler finished, detect errors
x-compressed-tar -
20.95 kB -
10/13/2024 at 20:11
Download
PEACLS_20241013.tgz
PEAC Line Scrambler, first VHDL version (the prefix check is still missing)
x-compressed-tar -
20.48 kB -
10/13/2024 at 06:08
Download
orbit_resume_64.c
sequential scanner adapted to 64-bit values. Can disable MSB masking.
x-csrc -
2.13 kB -
10/01/2024 at 05:22
Download
gPEAC_1M.tbz
Sieve generator, sieve, and scanner for the gPEAC orbits, "1 million" edition.
x-bzip-compressed-tar -
81.95 kB -
05/17/2023 at 14:51
Download
gPEAC_scans_1M.tbz
All the logs of the scan up to 1000615, and updated scripts. Raw data for those playing at home and wanting to reproduce everything (or in case of mistake)
2.37 MB -
05/17/2023 at 12:43
Download
gPEAC_500K.tbz
Sieve generator with the 501K range (47038 known orbits), sieve program, orbit scanner with fancy xterm launcher...
283.89 kB -
05/09/2023 at 02:11
Download
gPEAC_scan_logs_501K.tbz
all the maximal and perfect orbits of gPEAC, from 2 to 501000. .h file included. duplicate 89651 fixed.
1.13 MB -
05/09/2023 at 01:20
Download
gPEAC_scan.tgz
The new faster scanner ! see log 150.
x-compressed-tar -
51.74 kB -
05/06/2023 at 07:54
Download
sieve_booster.tgz
much better version than sieve.tgz
x-compressed-tar -
49.13 kB -
05/06/2023 at 06:00
Download
sieve.tgz
checks if a 64-bit number is a bad candidate (command-line program)
x-compressed-tar -
1.96 kB -
05/06/2023 at 00:35
Download
create_sieve.tgz
A C program to generate a sieve from the gPEAC.2-131540.txt log
x-compressed-tar -
37.14 kB -
05/05/2023 at 23:21
Download
gPEAC_optimsation.tgz
A collection of increasingly optimised gPEAC scan routines, as well as the proofing and benchmarking codes and scripts. See log 144. "More results !"
x-compressed-tar -
10.19 kB -
05/04/2023 at 00:01
Download
bench.diff_float.c
differential benchmarking stub. orbits.c not provided yet.
x-csrc -
2.95 kB -
05/01/2023 at 19:46
Download
bench.basic.c
uses RDTSC to evaluate the jitter of POSIX SIGALRM/setitimer
x-csrc -
1.52 kB -
04/30/2023 at 10:47
Download
gPEAC.2-131540.txt.gz
List of maximal and perfect orbits, from 2 to 131540.
gzip -
101.30 kB -
04/05/2022 at 02:03
Download
moduli_02.c
like moduli_01.c but can handle larger data, for m>65K
x-csrc -
1.17 kB -
01/29/2022 at 21:36
Download
mods.log
1880 first results with maximal or double-maximal orbit lengths
x-log -
40.00 kB -
01/29/2022 at 20:36
Download
moduli_01.c
check orbit length for non-power-of-two moduli
x-csrc -
1.14 kB -
01/29/2022 at 20:36
Download
fusion_20220109.tgz
contains dump7ck, pscan_10 and fusion, good enough to test up to w26.
x-compressed-tar -
7.13 kB -
01/09/2022 at 13:34
Download
log.22.p7k.bz2
p7k log of w22 compressed with bzip2.
x-bzip -
37.18 MB -
01/08/2022 at 00:30
Download
logs_p7k_03-21.tbz
p7k logs of w3 to w21 (compressed with bzip2).
34.55 MB -
01/08/2022 at 00:27
Download
dump7ck.tgz
dump a binary p7k file into a human-readable ASCII stream to stdout
application/x-compressed-tar -
2.06 kB -
01/03/2022 at 09:30
Download
pscan_20211229.tgz
enhanced version of the threaded scanner
x-compressed-tar -
5.09 kB -
12/29/2021 at 08:39
Download
pscan_20211224.tgz
pthread-enabled version for parallel-scanning. outputs p7k-formatted logs.
x-compressed-tar -
4.35 kB -
12/24/2021 at 12:34
Download
parscan01.tgz
New scanner with distributed ranges, p7k packing format and a couple of scripts
x-compressed-tar -
3.04 kB -
12/14/2021 at 05:06
Download
scan_1x_02.c
A basic single-threaded scanner for the smaller widths.
x-csrc -
2.53 kB -
12/04/2021 at 23:17
Download
faster_05.c
A reference code for the scan algorithm: unrolled 2× and handles semi-arcs. Condition bug is solved.
x-csrc -
1.77 kB -
12/03/2021 at 21:57
Download
p4ck.c
packs 2 decimal digits in one byte
x-csrc -
1.37 kB -
12/03/2021 at 18:15
Download
kc4p.c
unpacks a byte into two decimal digits
x-csrc -
1.04 kB -
12/03/2021 at 18:15
Download
snippets_v3.c
basic PRNG, checksum, scrambler/descrambler (sans and avec carry) using PEACw16 in C
x-csrc -
4.39 kB -
10/10/2021 at 14:28
Download
sous-titres.txt
subtitles for the French version of the video about trthe PEAC generator
plain -
14.63 kB -
10/06/2021 at 09:30
Download
zoumout2.tgz
files to compute and render the 16 zoom-out videos
x-compressed-tar -
2.82 kB -
09/14/2021 at 04:19
Download
Marsiglia _ add with carry RNG 1177005878.pdf
Some great theory from 1991
Adobe Portable Document Format -
1.76 MB -
09/14/2021 at 04:17
Preview
html_slides.tgz
files for log73.
x-compressed-tar -
1.27 kB -
09/06/2021 at 01:18
Download
zoumout.tgz
all the files (except the music) necessary to rebuild the zoom-out video.
x-compressed-tar -
2.91 kB -
08/16/2021 at 10:49
Download
bidir_orbit_01.c
Finally a bidirectional scanner that works.
x-csrc -
5.96 kB -
08/15/2021 at 08:49
Download
Pisano16x2_v5.c
Interim version. Some promising features appear but the code for the unrolled function is not "good".
x-csrc -
5.28 kB -
08/09/2021 at 01:11
Download
PEAC4x2.cjs
Circuitjs file for a 4-tap LFSR-like structure.
cjs -
6.83 kB -
08/08/2021 at 00:10
Download
test_Pisano16x2_v3.c
more features to check mixing and collisions.
x-csrc -
1.64 kB -
08/06/2021 at 08:04
Download
Pisano16x2_v3.c
Additive version
x-csrc -
2.02 kB -
08/06/2021 at 08:03
Download
case_against_xor.tgz
some files that compare XOR and ADD for mixing.
x-compressed-tar -
1.97 kB -
08/06/2021 at 07:11
Download
1dcasim_a.html.txt
Sim as below, with broadcast command feature.
plain -
11.65 kB -
08/04/2021 at 03:11
Download
1dcasim_9.html.txt
Sim of the chain protocol, with a working and more accurate addressing system.
plain -
10.64 kB -
07/27/2021 at 05:45
Download
1dcasim_7.html.txt
simulation of the queue insertion system for the FPGA interco. Rename the file, remove.txt
plain -
7.40 kB -
07/25/2021 at 02:53
Download
1dcasim_5.html.txt
a dynamic HTML simulator for the interco chain in FPGA. preliminary and incomplete.
plain -
5.28 kB -
07/24/2021 at 23:50
Download
dispatch_02.c
enabling computation of arcs in w32
x-csrc -
2.42 kB -
07/18/2021 at 02:15
Download
PEAC_core.tgz
First test of a VHDL version
x-compressed-tar -
1.54 kB -
07/13/2021 at 02:41
Download
job_logs.tgz
log files for w3 up to w20
x-compressed-tar -
18.09 MB -
07/09/2021 at 23:49
Download
gold_01.c
First working scanner to explore the behaviour of the "jobs" (serial version)
text/x-csrc -
1.47 kB -
07/09/2021 at 22:14
Download
test_w26.c
Compare the original (bit-limited) algo with the new (non-masking) algo.
x-csrc -
1.29 kB -
06/18/2021 at 00:42
Download
Pisano16x2_v2.c
Faster checksumming routine, with 16 and 32 bits versions.
x-csrc -
1.30 kB -
05/25/2021 at 11:42
Download
pt_orbit_07.c
runs both forward and backwards iterations in parallel, sometimes they meet in the middle.
x-csrc -
8.32 kB -
05/25/2021 at 04:10
Download
orbits_forwd2.c
Microbenchmark that compares the running time of forward and backwards computation.
x-csrc -
1.78 kB -
05/13/2021 at 03:21
Download
orbit_resume.c
same as orbit_count.c but with command line options to resume the search at a given point.
x-csrc -
1.99 kB -
05/07/2021 at 06:03
Download
Pisano16x2.c
A simple function that computes the checksum of a buffer.
x-csrc -
815.00 bytes -
04/29/2021 at 01:21
Download
test_Pisano16x2.c
a dumb main() to verify that Pisano16x2.c works.
x-csrc -
469.00 bytes -
04/29/2021 at 01:21
Download
orbit_count.c
Measures the first orbit of the Pisano-Carry state space (the long way)
x-csrc -
1.28 kB -
04/27/2021 at 05:08
Download
orbits_anim.c
Generates one image for each step of computation. (updated version)
text/x-csrc -
4.92 kB -
04/26/2021 at 12:33
Download
orbits_bmp.c
maps the full state space of the algorithms for arbitrary bit widths and export this map to .bmp files
x-csrc -
4.81 kB -
04/26/2021 at 01:55
Download
orbits.c
maps the full state space of the algorithms for arbitrary bit widths.
x-csrc -
3.09 kB -
04/25/2021 at 04:28
Download
prng.c
A toy PRNG that outputs 16 bit per cycle, with 65 bits of entropy.
x-csrc -
1.19 kB -
04/21/2021 at 03:38
Download
orbits_fs16c2.c
maps ALL 8G states and proves the structure of the orbits. Requires > 8GB RAM and 1/4h running time...
x-csrc -
5.63 kB -
04/19/2021 at 18:39
Download
Orbits_FS16C2_v2.html.txt
More accurate version that takes the carry into account for the intersections. Still not valid, see the C code!
plain -
3.05 kB -
04/19/2021 at 01:15
Download
Orbits_FS16C2.html.txt
Enumerate all the 10 orbits that go through X=1 Gives inaccurate results.
plain -
2.96 kB -
04/18/2021 at 02:04
Download
Orbits_FS16x2.html.txt
Fibonacci checksum test : Checks if 2 states X,Y,C belong to the same orbit of the 16×2 configuration with carries.
plain -
1.99 kB -
04/18/2021 at 00:01
Download
FiboSum16x2.html.txt
plain -
1.73 kB -
04/16/2021 at 04:26
Download
test_wrap64K.carry.html.txt
check that the sequence runs for 2G cycles (takes "several seconds" to compute...) for a 2×16 bits system with carry.
plain -
1.24 kB -
04/14/2021 at 04:08
Download
test_wrap64K.html.txt
Pisano mod 65536
plain -
1.14 kB -
04/14/2021 at 02:54
Download
test_wrap256.html.txt
Pisano mod 256
plain -
996.00 bytes -
04/14/2021 at 02:54
Download
