I just uploaded the file gPEAC.2-131540.txt.gz which contains the results of a long scanning campaign in early February.
From 2 to 131540, there are 13646 maximal and/or perfect sizes, among them 3858 are perfect.
I should plot the density vs value, and the gaps, or histograms thereof...
One very interesting and unexpected find (already noted at wow.) is that :
- Maximal (semi-perfect) systems have a modulus ending with the decimal digits 0, 1, 3, 4, 5, 6, or 9.
- Perfect systems have a modulus ending with the decimal digits 0, 4, 6, or 8.
Weren't we looking for some sort of pattern ? Well, there could be one and I included it in the latest scanner's code: scanning stops if the last digit is either 2 or 7 (with the exceptions of size=2).
There is a blind spot however: the scan only cared for 2 cases but we would need the whole data, including the length and count of all the orbits, in order to "predict" if a given modulus is promising (at least we can eliminate some candidates.
Let's review the actual moduli of the binary PEAC
1 2 perfect (a noted outlier and exception) 2 4 maximal 3 8 maximal 4 16 maximal 5 32 6 64 7 128 8 256 9 512 (impossible) 10 1024 maximal 11 2049 12 4096 13 8192 (impossible) 14 16384 15 32768 16 65536 maximal 17 131072 (impossible) 18 262144 19 524288 20 1048576 21 2097152 (impossible) 22 4194308 23 8388608 24 16777216 25 33554432 (impossible) 26 67108864 perfect ?
From there we can know which powers of 2 to skip:
27 134217728 28 268435456 29 536870912 (impossible) 30 1073741824 31 2147483648 32 4294967296 33 8589934592 (impossible) 34 17179869184 etc.
Better : this can help with finding better candidates for the hash moduli.
sqrt(2^33) = 92681 sqrt(2^35) = 185363 sqrt(2^37) = 370727 (impossible) sqrt(2^39) = 741455 sqrt(2^41) = 1482910 maybe perfect sqrt(2^43) = 2965820 maybe perfect sqrt(2^45) = 5931641 sqrt(2^47) = 11863283 sqrt(2^49) = 23726566 maybe perfect sqrt(2^51) = 47453132 (impossible) sqrt(2^53) = 94906265 sqrt(2^55) = 189812531 sqrt(2^57) = 379625062 (impossible) sqrt(2^59) = 759250124 maybe perfect sqrt(2^61) = 1518500249 sqrt(2^63) = 3037000499 sqrt(2^65) = 6074000999 sqrt(2^67) = 12148001999 sqrt(2^69) = 24296003999 sqrt(2^71) = 48592007999 sqrt(2^73) = 97184015999 sqrt(2^75) = 194368031998 maybe perfect sqrt(2^77) = 388736063996 maybe perfect sqrt(2^79) = 777472127993 sqrt(2^81) = 1554944255987 (impossible) etc.
But this is for now purely observational and 2^3=8 is an exception to the semi-perfect rule. I'm sure I miss something.
So not only should I recompute these numbers completely, but also plot them to BMP and count the number of orbits, like I did for the videos.
I should also examine the existing list with other bases (not just base 10, but prime bases, so maybe there is another link with Galois Fields ?) and understand why 2 and 7 are exceptions (note: they are 5 apart, mod 10)
This is really so strange... I suspect some prime-number tricky business here.
