My latest article is published and it's a killer !
It will be fully open around mid-2023. It packs a thorough analysis of existing checksums to deduce/develop the structure and the theory of PEAC checksums. A must-read for anyone who understands French and wants to develop or implement their own checksum!
So I looked around and found that PEAC was picked up by https://en.wikibooks.org/wiki/Algorithm_Implementation/Checksums. I'd like to contribute a coding example but so far I have only coded it in C, asm and JS. Who wants to make other versions of the checksum in Python, Perl, Pascal, ...Psomethingelse ?
DavidCary, if you read this, here's a first snippet to add to the PEAC page:
// PEAC16x2 algorithm, not unrolled.
// Good practice : Pad the end of the buffer
// with 2 words (can be 0) to increase mixing.
#include <stdint.h>
uint32_t PEAC16x2(int len, uint16_t *src) {
uint16_t X=0xABCD;
uint32_t Y=0x4567,
C=len; // add the size of the buffer to the checksum
while (len > 0) {
C += X;
len--;
C += Y;
Y = X + *src;
X = C & 0xFFFF;
C >>= 16;
src++;
// return 32 bits
return X | (Y << 16);
The JavaScript version is almost identical, if we modify the declaration, the data types and the array indexing.
// PEAC16x2 algorithm, not unrolled, in JS.
function PEAC16x2(len, src) {
var X=0xABCD,
Y=0x4567,
C=len,
i=0;
while (len > 0) {
C += X + Y;
len--;
Y = X + src[i++];
X = C & 0xFFFF;
C >>= 16;
What's next ?
