Line encoding with PEAC: it's alive.
A project log for PEAC Pisano with End-Around Carry algorithm
Add X to Y and Y to X, says the song. And carry on.
yann-guidon-ygdesYann Guidon / YGDES 10/13/2024 at 03:210 Comments
I just had a first successful test run in VHDL using w16. It's not finished but the result is almost as good as I expected.
[yg@Rizen5 PEACLS]$ ./runme.sh
  In=0000000000000000 X:010000000000000000  Out=0000000000000000
  In=0000000000000000 X:011101110101101101  Out=0000000000000000
  In=0000100000000000 X:010111010111011011  Out=0000100000000000
  In=0000000000000000 X:000100101101001001  Out=0000000000000000
  In=0000000000000000 X:011100000100100101  Out=0000000000000000
  In=0000000000000000 X:000000110001101110  Out=0000000000000000
  In=0000000000000000 X:001100110110010100  Out=0000000000000000
  In=0000000000000000 X:011101101000000010  Out=0000000000000000
  In=0000000000000000 X:011010011110010110  Out=0000000000000000
  In=0000000000000000 X:011000000110011001  Out=0000000000000000
  In=0000000000000000 X:000010100100110000  Out=0000000000000000
  In=0000000000000000 X:001010101011001010  Out=0000000000000000
  In=0000000000000000 X:011101001111111010  Out=0000000000000000
  In=0000000000000000 X:010111111011000100  Out=0000000000000000
  In=0000000000010000 X:000101001011001111  Out=0000000000010000
  In=0000000000000000 X:011101000110000100  Out=0000000000000000
  In=0000000000000000 X:000010010001010011  Out=0000000000000000
  In=0000000000000000 X:011111010111011000  Out=0000000000000000
  In=0000000000000000 X:010001101000101011  Out=0000000000000000
  In=0000000000000000 X:000001000000000100  Out=0000000000000000
  In=0000000000000000 X:000010101000110000  Out=0000000000000000
  In=0000000000000000 X:000011101000110100  Out=0000000000000000
  In=0000000000000000 X:000110010001100100  Out=0000000000000000
  In=0000000000000000 X:011001111010011000  Out=0000000000000000
  In=0000000000000000 X:000000001011111100  Out=0000000000000000
  In=0000000000000000 X:001010000110010101  Out=0000000000000000
  In=0000000000000000 X:011010010010010001  Out=0000000000000000
  In=0000000000000000 X:000100011000100110  Out=0000000000000000
  In=0000000000000000 X:011110101010111000  Out=0000000000000000
  In=0000000000000000 X:010011000011011110  Out=0000000000000000
  In=0000000000000000 X:000001101110010111  Out=0000000000000000
  In=0000000000000000 X:000100110001110110  Out=0000000000000000
I send 2 individual bits and the data on the line (X) is a nice mess. The output is exactly as expected however!
The "schematics" are almost straight out of 79. Taxonomy:
Encoder:
Decoder:
There is a slight delay due to pipelining/buffering so the output log above is "compressed".
I can play with the INIT_X and INIT_Y values, for now I use
INIT_X <= "0110110111011011";
INIT_Y <= "1101110101101101";
One thing I notice though is that the D bit is very dependent on the input message. When there is no input entropy, the prefix/HA output is either 00 or 01, barely ever 10. C seems to have a good behaviour but I need a way to toggle D more. Or even remove D...
But otherwise, so far it's a success, almost like expected.
_____________________________________________
I updated the "circuit" because the D should subtracted from the message, instead of added.
So this solves a "little problem" with the output that gets off-by-one in certain situations.
Get PEACLS_20241013.tgz !
The carries will give a lot of problems, for sure. The 2-bit prefix depends a LOT on the message's MSB, for example. But the XOR part is quite good.
