My friend François designed a SBC sporting a Hitachi 6309E, a faster and extended version of the venerable Motorola 6809. Looking at its instruction set table, I find that it has instructions that handle 16 bits at once on the D register (made of the A and B byte accumulators). This is actually pretty suitable for a PEAC16×2 algorithm, which is way better than the xorsum currently used...
But François said :
- the program must use the LEAST number of bytes
- the checksum is reduced down to one byte
- the scanning range can be from one to 2^16 bytes.
PEAC16×2 works with pairs of bytes so the eventual extra odd byte must be handled separately at the end. And there is no notion of alignment, but the 6809 is a Big Endian machine. Since the constraint is placed on the code size and not the speed, the algorithm loop would work on individual bytes, not 16-bit words.
At first look, the algorithm is more complex and larger than xorsum but a first enhancement would replace the xor with add, and reuse the carry: this is not foolproof but requires very little effort to implement.
Replacing xor8 with adc8 divides the error rate by two :
