While trying to estimate the size of the complete set of arc data for w32, I wrote dispatch_02.c and let it run for a minute or so...
$ gcc -Wall -DWIDTH=32 -Os dispatch_02.c -o dispatch && ./dispatch Run on W32 from 42 to 1500 42 -> X=2656939159 N=5996278162 l=5 43 -> X=2529572078 N=1751451951 l=5 44 -> X=4217682635 N=9651841000 l=5 45 -> X= 528636580 N=9545525216 l=5 46 -> X= 626411012 N=855984539 l=5 47 -> X=1331873985 N=1897705442 l=5 48 -> X=3644464132 N=2553832670 l=5 49 -> X= 955492511 N=2834782532 l=5 50 -> X=2905244640 N=10158815173 l=5 51 -> X=3977561810 N=570944009 l=5 52 -> X=1285427445 N=1916254633 l=5 53 -> X=2722001243 N=8057574457 l=5 54 -> X=1572286052 N=2556104354 l=5 55 -> X=1183375166 N=3596834417 l=5 56 -> X=1423688005 N=2467949744 l=5 57 -> X=1992353645 N=1488849858 l=5 58 -> X= 208628631 N=3750365940 l=5 59 -> X=3057416295 N=269839798 l=5 60 -> X=3795627370 N=5996278162 l=5 61 -> X=2510464790 N=251891606 l=4 62 -> X=1770417005 N=8459247511 l=5 63 -> X= 740091212 N=9545525216 l=5 64 -> X=3908705066 N=691897578 l=5 65 -> X=2100730390 N=3511641358 l=5 66 -> X=4175190107 N=5996278162 l=5 67 -> X=3476866509 N=1904497197 l=5 68 -> X=1024457701 N=3162422531 l=5 69 -> X= 939616518 N=855984539 l=5 70 -> X=1593588803 N=5245804944 l=5 71 -> X= 21251938 N=1049143365 l=5 72 -> X= 53655981 N=5873919413 l=5 ^C
Using a MIDI-like "variable length code", I see an average of 5 bytes of the size of an arc.
This means that 4Gi arcs × (4+5 bytes) = about 40GB, not including duplicates for verifications. The file(s) may be streamed, but the tabulation will require more than 64GB of RAM.
