The log 79. Taxonomy has 2 versions of the scrambler, and although the first one is simpler, without the dedicated carry flag, this absence makes it less effective. I have tested it a bit and found that while errors are preserved, they are not propagated...
A further examination with clear test benches should appear below :-)
To be completed
