So here is the (slightly edited) log of the first run with the new program:
$ cat pass.sh
#!/bin/bash
# arguments :
# $1 = filename of source .p7k
# $2 = filename of destination .p7k
TMP_SRC="tmp_src.p7k"
TMP_DST="tmp_dst.p7k"
LC_ALL=C sort -z -k 1.1,1.5 $1 > $TMP_SRC
LC_ALL=C sort -z -k 1.6,1.10 $1 > $TMP_DST
./fusion U $TMP_SRC $TMP_DST $2
$ cat fuse03.sh
./pass.sh log.03.p7k log.03.pass1.p7k
./pass.sh log.03.pass1.p7k log.03.pass2.p7k
./pass.sh log.03.pass2.p7k log.03.pass3.p7k
./pass.sh log.03.pass3.p7k log.03.pass4.p7k
./pass.sh log.03.pass4.p7k log.03.pass5.p7k
$ . fuse03.sh
index=0 : fuse
index=1 : copy src
index=2 : fuse
index=3 : copy dst
index=4 : fuse
index=5 : nothing
index=6 : nothing
index=7 : nothing
writing 5
index=1 : fuse
index=3 : fuse
index=5 : copy dst
index=6 : nothing
index=7 : nothing
writing 3
index=5 : fuse
index=6 : copy dst
index=7 : nothing
writing 2
index=6 : fuse
index=7 : nothing
writing 1
index=7 : LOOP FOUND: len=35 arcs=8 at 7
writing 0
I have to run more tests but it seems to work very nicely.
A better version:
$ cp log.03.p7k tmp.p7k
$ while [ -s tmp.p7k ]; do
> ls -al tmp.p7k
> ./pass.sh tmp.p7k tmp.p7k
> done
208 9 janv. 12:16 tmp.p7k
130 9 janv. 12:16 tmp.p7k
78 9 janv. 12:16 tmp.p7k
52 9 janv. 12:16 tmp.p7k
26 9 janv. 12:16 tmp.p7k
The loop is ready for working with other sizes :-)
[yg]$ cat fuse.sh
TMP="tmp.p7k"
cp log.05.p7k tmp.p7k
while [ -s $TMP ]; do
# ls -al $TMP
LC_ALL=C sort -z -k 1.1,1.5 $TMP > $TMP_SRC
LC_ALL=C sort -z -k 1.6,1.10 $TMP > $TMP_DST
./fusion U $TMP_SRC $TMP_DST $TMP
done
[yg]$ ./fuse.sh
LOOP FOUND: len=21 arcs=1 at 5
LOOP FOUND: len=21 arcs=1 at 10
LOOP FOUND: len=21 arcs=1 at 15
LOOP FOUND: len=21 arcs=1 at 30
LOOP FOUND: len=21 arcs=2 at 25
LOOP FOUND: len=84 arcs=4 at 21
LOOP FOUND: len=84 arcs=3 at 22
LOOP FOUND: len=84 arcs=5 at 28
LOOP FOUND: len=84 arcs=8 at 29
LOOP FOUND: len=84 arcs=6 at 31
I seem to be getting one half of the orbit numbers :
$ cp ../ref.p7k/log.06.p7k tmp.p7k
$ ./fuse.sh
LOOP FOUND: len=693 arcs=23 at 62
LOOP FOUND: len=693 arcs=21 at 63
LOOP FOUND: len=693 arcs=20 at 60
In the log 16. More orbits ! I found 6 orbits for w6 but only 3 are reported here.
This is explained by the fact that the new scanner scans the semi-arcs, that is : each semi-arc walks 2 arcs at the same time. So the number of loops/orbits must be doubled.
$ cp ../ref.p7k/log.07.p7k tmp.p7k; ./fuse.sh LOOP FOUND: len=45 arcs=1 at 79 LOOP FOUND: len=234 arcs=2 at 110 LOOP FOUND: len=234 arcs=2 at 121 LOOP FOUND: len=390 arcs=6 at 114 LOOP FOUND: len=234 arcs=7 at 99 LOOP FOUND: len=1170 arcs=13 at 119 LOOP FOUND: len=1170 arcs=20 at 126 LOOP FOUND: len=1170 arcs=16 at 117 LOOP FOUND: len=1170 arcs=15 at 122 LOOP FOUND: len=1170 arcs=20 at 118 LOOP FOUND: len=1170 arcs=26 at 127
w7: 22 orbits instead of 26.
$ cp ../ref.p7k/log.08.p7k tmp.p7k; ./fuse.sh |wc -l 167
w8 can find only 167 of the estimated 572 orbits, all of length 115. But it doesn't matter since we're only interested in statespaces with only one couple of orbits.
$ cp ../ref.p7k/log.09.p7k tmp.p7k; ./fuse.sh |wc -l
53
w9 only shows orbits with 200, 260 and 2600 steps.
$ cp ../ref.p7k/log.10.p7k tmp.p7k; ./fuse.sh
LOOP FOUND: len=524799 arcs=1024 at 1023
w10 looks perferct, as expected.
$ cp ../ref.p7k/log.11.p7k tmp.p7k; ./fuse.sh LOOP FOUND: len=2922 arcs=5 at 1795 LOOP FOUND: len=1046076 arcs=1038 at 2047 LOOP FOUND: len=1046076 arcs=1005 at 2046
w11 finds only 6 orbits out of 8 but the lengths do not match 5844 or 179 (1046076 is correct though)
$ cp ../ref.p7k/log.12.p7k tmp.p7k; ./fuse.sh LOOP FOUND: len=71107 arcs=34 at 3894 LOOP FOUND: len=71107 arcs=35 at 4071 LOOP FOUND: len=2062103 arcs=1032 at 4093 LOOP FOUND: len=2062103 arcs=986 at 4094 LOOP FOUND: len=2062103 arcs=990 at 4095 LOOP FOUND: len=2062103 arcs=1019 at 4086
w12 finds 12 of the 14 orbits, and misses only a couple of 29-long ones.
$ cp ../ref.p7k/log.13.p7k tmp.p7k; ./fuse.sh|wc -l 130
w13 finds 130 of the 196 orbits, finding lengths of 103257 and 413028 instead of 4, 206514, 413028 (it seems that 206514 is the double of 103257)
Let's be crazy and count the passes:
$ for i in ../ref.p7k/log.*k; do echo -n "* $i : "; cp $i tmp.p7k; ./fuse.sh; done
* ../ref.p7k/log.02.p7k : 4 passes
* ../ref.p7k/log.03.p7k : 5 passes
* ../ref.p7k/log.04.p7k : 9 passes
* ../ref.p7k/log.05.p7k : 5 passes
* ../ref.p7k/log.06.p7k : 9 passes
* ../ref.p7k/log.07.p7k : 9 passes
* ../ref.p7k/log.08.p7k : 4 passes
* ../ref.p7k/log.09.p7k : 9 passes
* ../ref.p7k/log.10.p7k : 25 passes
* ../ref.p7k/log.11.p7k : 23 passes
* ../ref.p7k/log.12.p7k : 28 passes
* ../ref.p7k/log.13.p7k : 19 passes
* ../ref.p7k/log.14.p7k : 32 passes
* ../ref.p7k/log.15.p7k : 12 passes
* ../ref.p7k/log.16.p7k : 37 passes
* ../ref.p7k/log.17.p7k : 28 passes
* ../ref.p7k/log.18.p7k : 31 passes
* ../ref.p7k/log.19.p7k : 28 passes
* ../ref.p7k/log.20.p7k : 30 passes
* ../ref.p7k/log.21.p7k : 47 passes
* ../ref.p7k/log.22.p7k : 53 passes
* ../ref.p7k/log.23.p7k : 61 passes
* ../ref.p7k/log.24.p7k : 51 passes
* ../ref.p7k/log.25.p7k : 54 passes
This is not monotonic...
The runtimes are very short for the widths below 20. They explode after that. The fusion step is pretty quick compared with the 2 sorts (this vindicates my approach). w25 took 3:21 minutes:
$ cp ../ref.p7k/log.25.p7k tmp.p7k
$ /usr/bin/time ./fuse.sh
sort src
sort dst
fusion
LOOP FOUND: len=19795484 arcs=1 at 17051949
LOOP FOUND: len=19795484 arcs=1 at 20841271
LOOP FOUND: len=26225834 arcs=1 at 21451665
LOOP FOUND: len=178159356 arcs=1 at 23832841
LOOP FOUND: len=19795484 arcs=1 at 24630593
LOOP FOUND: len=19795484 arcs=1 at 28419915
LOOP FOUND: len=19795484 arcs=1 at 32209237
sort src
sort dst
fusion
LOOP FOUND: len=19795484 arcs=2 at 18946610
LOOP FOUND: len=19795484 arcs=2 at 26525254
sort src
sort dst
fusion
LOOP FOUND: len=19795484 arcs=3 at 22735932
LOOP FOUND: len=52451668 arcs=3 at 25741998
LOOP FOUND: len=26225834 arcs=3 at 28602220
LOOP FOUND: len=52451668 arcs=3 at 32892553
sort src
sort dst
fusion
LOOP FOUND: len=52451668 arcs=4 at 18591443
LOOP FOUND: len=52451668 arcs=5 at 22881776
LOOP FOUND: len=178159356 arcs=5 at 28918510
LOOP FOUND: len=19795484 arcs=5 at 30314576
LOOP FOUND: len=178159356 arcs=4 at 31411485
LOOP FOUND: len=52451668 arcs=4 at 31462442
sort src
sort dst
fusion
LOOP FOUND: len=178159356 arcs=6 at 29117948
LOOP FOUND: len=178159356 arcs=6 at 30514014
LOOP FOUND: len=178159356 arcs=8 at 31610923
LOOP FOUND: len=178159356 arcs=6 at 32109518
LOOP FOUND: len=236032506 arcs=8 at 32365670
LOOP FOUND: len=236032506 arcs=7 at 32742015
sort src
sort dst
fusion
LOOP FOUND: len=178159356 arcs=10 at 27721882
LOOP FOUND: len=178159356 arcs=13 at 29716262
LOOP FOUND: len=178159356 arcs=9 at 31810361
LOOP FOUND: len=178159356 arcs=6 at 32009799
LOOP FOUND: len=178159356 arcs=10 at 32807551
LOOP FOUND: len=178159356 arcs=8 at 33206427
LOOP FOUND: len=178159356 arcs=10 at 33405865
LOOP FOUND: len=178159356 arcs=7 at 33505584
sort src
sort dst
fusion
LOOP FOUND: len=178159356 arcs=19 at 25528064
LOOP FOUND: len=178159356 arcs=9 at 28120758
LOOP FOUND: len=236032506 arcs=13 at 30860290
LOOP FOUND: len=236032506 arcs=17 at 31989325
LOOP FOUND: len=178159356 arcs=18 at 32308956
LOOP FOUND: len=178159356 arcs=8 at 32707832
LOOP FOUND: len=178159356 arcs=15 at 32907270
LOOP FOUND: len=236032506 arcs=21 at 33118360
LOOP FOUND: len=178159356 arcs=14 at 33306146
LOOP FOUND: len=472065012 arcs=13 at 33344167
sort src
sort dst
fusion
LOOP FOUND: len=178159356 arcs=11 at 27422725
LOOP FOUND: len=178159356 arcs=11 at 31112328
LOOP FOUND: len=178159356 arcs=11 at 31311766
LOOP FOUND: len=178159356 arcs=17 at 31511204
LOOP FOUND: len=178159356 arcs=14 at 33006989
sort src
sort dst
fusion
LOOP FOUND: len=178159356 arcs=10 at 30713452
LOOP FOUND: len=472065012 arcs=30 at 31086097
LOOP FOUND: len=472065012 arcs=24 at 32290401
LOOP FOUND: len=178159356 arcs=17 at 32608113
LOOP FOUND: len=472065012 arcs=27 at 32817284
LOOP FOUND: len=472065012 arcs=27 at 32967822
LOOP FOUND: len=472065012 arcs=24 at 33043091
LOOP FOUND: len=472065012 arcs=32 at 33193629
LOOP FOUND: len=472065012 arcs=40 at 33268898
LOOP FOUND: len=472065012 arcs=28 at 33419436
sort src
sort dst
fusion
LOOP FOUND: len=472065012 arcs=27 at 28677489
LOOP FOUND: len=178159356 arcs=17 at 30813171
LOOP FOUND: len=472065012 arcs=38 at 31311904
LOOP FOUND: len=178159356 arcs=19 at 32408675
LOOP FOUND: len=472065012 arcs=27 at 32440939
LOOP FOUND: len=236032506 arcs=19 at 33494705
sort src
sort dst
fusion
sort src
sort dst
fusion
sort src
sort dst
fusion
sort src
sort dst
fusion
sort src
sort dst
fusion
sort src
sort dst
fusion
sort src
sort dst
fusion
LOOP FOUND: len=3752787212 arcs=216 at 33391113
sort src
sort dst
fusion
LOOP FOUND: len=3752787212 arcs=208 at 33511117
LOOP FOUND: len=3752787212 arcs=211 at 33541118
sort src
sort dst
fusion
LOOP FOUND: len=3752787212 arcs=260 at 33481116
sort src
sort dst
fusion
sort src
sort dst
fusion
LOOP FOUND: len=3752787212 arcs=223 at 33451115
sort src
sort dst
fusion
sort src
sort dst
fusion
LOOP FOUND: len=33775084908 arcs=1892 at 33549013
sort src
sort dst
fusion
LOOP FOUND: len=33775084908 arcs=1904 at 33537960
LOOP FOUND: len=33775084908 arcs=2203 at 33552171
sort src
sort dst
fusion
LOOP FOUND: len=33775084908 arcs=2003 at 33544276
LOOP FOUND: len=33775084908 arcs=2079 at 33547434
sort src
sort dst
fusion
LOOP FOUND: len=33775084908 arcs=2020 at 33536381
sort src
sort dst
fusion
LOOP FOUND: len=33775084908 arcs=1879 at 33484274
LOOP FOUND: len=33775084908 arcs=2020 at 33531644
LOOP FOUND: len=33775084908 arcs=2123 at 33553750
sort src
sort dst
fusion
sort src
sort dst
fusion
LOOP FOUND: len=33775084908 arcs=2009 at 33487432
sort src
sort dst
fusion
sort src
sort dst
fusion
sort src
sort dst
fusion
sort src
sort dst
fusion
sort src
sort dst
fusion
sort src
sort dst
fusion
LOOP FOUND: len=986983036756 arcs=58742 at 33554323
sort src
sort dst
fusion
LOOP FOUND: len=986983036756 arcs=57394 at 33553715
sort src
sort dst
fusion
LOOP FOUND: len=986983036756 arcs=59271 at 33552936
LOOP FOUND: len=986983036756 arcs=59106 at 33553202
LOOP FOUND: len=986983036756 arcs=59770 at 33553962
LOOP FOUND: len=986983036756 arcs=58117 at 33554228
LOOP FOUND: len=986983036756 arcs=60136 at 33554380
sort src
sort dst
fusion
LOOP FOUND: len=986983036756 arcs=59015 at 33551853
LOOP FOUND: len=986983036756 arcs=58325 at 33553829
LOOP FOUND: len=986983036756 arcs=57865 at 33554000
LOOP FOUND: len=986983036756 arcs=58377 at 33554171
LOOP FOUND: len=986983036756 arcs=59788 at 33554285
LOOP FOUND: len=986983036756 arcs=58043 at 33554304
LOOP FOUND: len=986983036756 arcs=59610 at 33554418
sort src
sort dst
fusion
LOOP FOUND: len=986983036756 arcs=57730 at 33553506
LOOP FOUND: len=986983036756 arcs=59057 at 33554114
LOOP FOUND: len=986983036756 arcs=58452 at 33554266
LOOP FOUND: len=986983036756 arcs=57995 at 33554399
sort src
sort dst
fusion
LOOP FOUND: len=986983036756 arcs=59284 at 33553392
LOOP FOUND: len=986983036756 arcs=58351 at 33553468
LOOP FOUND: len=986983036756 arcs=58905 at 33553943
LOOP FOUND: len=986983036756 arcs=60273 at 33554190
sort src
sort dst
fusion
LOOP FOUND: len=986983036756 arcs=57518 at 33553335
LOOP FOUND: len=986983036756 arcs=59531 at 33554247
sort src
sort dst
fusion
LOOP FOUND: len=986983036756 arcs=59168 at 33553886
LOOP FOUND: len=986983036756 arcs=59579 at 33554152
sort src
sort dst
fusion
LOOP FOUND: len=986983036756 arcs=59290 at 33553601
LOOP FOUND: len=986983036756 arcs=58585 at 33553639
LOOP FOUND: len=986983036756 arcs=58788 at 33554342
sort src
sort dst
fusion
LOOP FOUND: len=8882847330804 arcs=529231 at 33554384
sort src
sort dst
fusion
LOOP FOUND: len=8882847330804 arcs=529834 at 33554328
LOOP FOUND: len=8882847330804 arcs=528831 at 33554334
LOOP FOUND: len=8882847330804 arcs=529190 at 33554382
sort src
sort dst
fusion
LOOP FOUND: len=8882847330804 arcs=529350 at 33554381
LOOP FOUND: len=8882847330804 arcs=532532 at 33554385
LOOP FOUND: len=8882847330804 arcs=531407 at 33554389
LOOP FOUND: len=8882847330804 arcs=529846 at 33554391
LOOP FOUND: len=8882847330804 arcs=530113 at 33554423
sort src
sort dst
fusion
LOOP FOUND: len=8882847330804 arcs=527946 at 33554298
LOOP FOUND: len=8882847330804 arcs=532155 at 33554300
LOOP FOUND: len=8882847330804 arcs=530758 at 33554396
LOOP FOUND: len=8882847330804 arcs=528028 at 33554410
LOOP FOUND: len=8882847330804 arcs=531275 at 33554416
LOOP FOUND: len=8882847330804 arcs=526611 at 33554420
LOOP FOUND: len=8882847330804 arcs=529170 at 33554427
LOOP FOUND: len=8882847330804 arcs=532392 at 33554431
sort src
sort dst
fusion
LOOP FOUND: len=8882847330804 arcs=528830 at 33554219
LOOP FOUND: len=8882847330804 arcs=529888 at 33554283
LOOP FOUND: len=8882847330804 arcs=526382 at 33554330
LOOP FOUND: len=8882847330804 arcs=528509 at 33554338
LOOP FOUND: len=8882847330804 arcs=527469 at 33554353
LOOP FOUND: len=8882847330804 arcs=528421 at 33554378
LOOP FOUND: len=8882847330804 arcs=530706 at 33554407
LOOP FOUND: len=8882847330804 arcs=529389 at 33554408
LOOP FOUND: len=8882847330804 arcs=530892 at 33554415
LOOP FOUND: len=8882847330804 arcs=529101 at 33554421
LOOP FOUND: len=8882847330804 arcs=529751 at 33554422
LOOP FOUND: len=8882847330804 arcs=531479 at 33554425
sort src
sort dst
fusion
LOOP FOUND: len=8882847330804 arcs=529274 at 33554251
LOOP FOUND: len=8882847330804 arcs=530351 at 33554258
LOOP FOUND: len=8882847330804 arcs=530362 at 33554274
LOOP FOUND: len=8882847330804 arcs=529354 at 33554303
LOOP FOUND: len=8882847330804 arcs=527139 at 33554343
LOOP FOUND: len=986983036756 arcs=58799 at 33554361
LOOP FOUND: len=8882847330804 arcs=531352 at 33554366
LOOP FOUND: len=8882847330804 arcs=528804 at 33554375
LOOP FOUND: len=8882847330804 arcs=529109 at 33554393
LOOP FOUND: len=8882847330804 arcs=527618 at 33554394
LOOP FOUND: len=8882847330804 arcs=527423 at 33554395
LOOP FOUND: len=8882847330804 arcs=529584 at 33554409
LOOP FOUND: len=8882847330804 arcs=528920 at 33554413
LOOP FOUND: len=8882847330804 arcs=529147 at 33554414
LOOP FOUND: len=8882847330804 arcs=529119 at 33554424
LOOP FOUND: len=8882847330804 arcs=528099 at 33554429
sort src
sort dst
fusion
LOOP FOUND: len=8882847330804 arcs=530110 at 33554355
LOOP FOUND: len=8882847330804 arcs=530052 at 33554368
LOOP FOUND: len=8882847330804 arcs=530154 at 33554392
LOOP FOUND: len=8882847330804 arcs=529041 at 33554397
LOOP FOUND: len=8882847330804 arcs=532306 at 33554400
LOOP FOUND: len=8882847330804 arcs=528006 at 33554401
sort src
sort dst
fusion
LOOP FOUND: len=8882847330804 arcs=526779 at 33554294
LOOP FOUND: len=8882847330804 arcs=530920 at 33554309
LOOP FOUND: len=8882847330804 arcs=528471 at 33554336
LOOP FOUND: len=8882847330804 arcs=530427 at 33554373
LOOP FOUND: len=8882847330804 arcs=528923 at 33554402
LOOP FOUND: len=8882847330804 arcs=529207 at 33554428
LOOP FOUND: len=8882847330804 arcs=526784 at 33554430
sort src
sort dst
fusion
LOOP FOUND: len=8882847330804 arcs=530015 at 33554268
LOOP FOUND: len=8882847330804 arcs=529894 at 33554426
sort src
sort dst
fusion
sort src
sort dst
fusion
LOOP FOUND: len=8882847330804 arcs=531307 at 33554376
54 passes
333.11user 22.72system 3:21.06elapsed 176%CPU
It's not particularly interesting but it gives a hint for the wider configurations.
And now, w26 !
The suspense was not great:
$ cp ../ref.p7k/log.26.p7k tmp.p7k
LOOP FOUND: len=2251799847239679 arcs=67108864 at 67108863
70 passes
744.97user 43.86system 7:35.98elapsed 172%CPU
So this is the final confirmation for w26 ! The only thing that it provides is that the runtime is "mostly doubled" from the previous run: 7:35 vs 3:21. This could be much faster since I use the older i7 with the spinning plates and I did not configure the swap file of sort. Anyway, this is going very well so far... And it took only 7 minutes to check the results of a computation that lasted 4 days...
Here are the sizes of the successive files:
1744830464 1163280898 814335548 585037336 427385062 315933592 235638806 176962318 133645772 101374338 58967662 77191868 58967662 34687822
To compute the ratio of shrinkage:
$ last=1744830464; for i in 1163280898 814335548 585037336 427385062 315933592 235638806 176962318 133645772 101374338 77191868 58967662 34687822 ; do echo "$i : " $(( (last-i) / (last/100) )); last=$i ; done1163280898 : 33
814335548 : 29
585037336 : 28
427385062 : 26
315933592 : 26
235638806 : 25
176962318 : 24
133645772 : 24
101374338 : 24
77191868 : 23
58967662 : 23
34687822 : 41
So yes, the ratio is approximately 25% as already supposed. It takes 2 passes to cut the size in half.
Sorting w32 should be about 100× longer, or about 12h. Pre-fusion is possible on partial results, I suppose, though I'll have to change the condition of termination for the main loop, which at this point checks if the result file is empty. I could compare the size of the input and output file...
______________________________________________________________
I'm not finished yet !
I was wondering about the structure of w24:
LOOP FOUND: len=1340357111847 arcs=159675 at 16777118
51 passes
138.07user 10.49system 1:33.16elapsed 159%CPU
I found 105 pairs of orbits of equal lengths=1.340.357.111.847 so this is not too bad... but w26 is still better :-)
