The v.02 boards arrived today and they look sooo much better than v.01. Although this board is a through-hole only version, it should be 100% functional.
I'm going to solder the components and make 2 modules, run some tests, and then make another post with my results.
Hopefully I can order the v.03 module before the weekend.
