I made this little Arduino Sketch for my VW Polo 9N3 cluster to emulate CAN BUS and let it believe whatever I want.
The Cluster is coming from a 2006 VW Polo 9N3 Diesel
Parts number: A2C53162939
The connector I use to plug the Arduino into the cluster is coming from a Skoda Fabia and has been modified by me. I use an Arduino UNO and a keyestudio CAN BUS Shield I bought off Aliexpress.
Currently working Things:
-Check Engine Light
-Disable or enable ABS
-Diesel Glowplugs
-Turn Signals
-Alternator Lamp
-Backlight
-Enable or disable Airbag Modules
Tell me if something isnt working and I will try to help as good as I can :)
I'm trying to find the CAN connections pins for this
VW Polo 9N3 Cluster. Any details would be great to know.
