Fully self-contained eZ80-based computing system with LCD and OPL sound
It turned out there were some things which required immediate fixing. The two expanders has their main connector inverted on the PCB! Of course, there is a way around, but it is much cleaner to have it in the right way.
The main board had some header holes too small. I must have changed those by mistake since they were fine in the previous version of the board. Anyway, fixed those too. Also, the crystal frequency is (finally!) set at 18.432 MHz.
All is fixed now and updated on the website.
I am not focused on making software, but for my knowledge there is an existing port of Nuttx for it. Also, this guy here has done quite a bit on Z20X too, and there are pictures: https://www.cocoacrumbs.com/
It should be able to, however, I am not aware of an existing port for it
can You show video (or photo) with working device?
screen, keyboard, etc.
