It is also possible to make engravings on cylindrical surfaces by turning the machine and adjusting the wheels, which will rotate the piece while the laser does its work.
Engraver and Cutter Machine - New Concept
This might be helpful: https://hackaday.io/project/179362-laser-air-assist-shootout
Do you have any provision for air-assist? I understand that forcefully ejecting the smoke from the cut zone is very important to maintaining cut quality. I see a fan there, but is that moving enough air to keep the lens clean?
Indeed, the laser has a fan that extracts the smoke from the bottom up, however it is not enough, so I have had to design a suction system that reaches through a small tube that is located near the beam of light. It is not published yet, once it is implemented it will be published.
