Metal bone
bone-like metal composite structure
I was born to do this.
After 40 years of teaching, I finally made it - a metal bone.
Most importantly - the cost of such technology is a few bucks*...
________________
* Literally - a few bucks.
The method is so brazenly simple and effective that children can use it.
Most homes have all the things you need to do this...
Mars will be crowded 😎
Compare the weight of a common copper heat sink and a sample:
https://www.tiktok.com/@michal_baran/video/6954171164251933957?lang=pl-PL&is_copy_url=0&is_from_webapp=v1&sender_device=pc&sender_web_id=6913950129183901190
fragment of rocket engine nozzle... ;)
JPEG Image - 1.03 MB - 04/22/2021 at 18:51
Preview
View all 2 project logs
aldolo wrote 04/25/2021 at 06:51 point
what am i looking at? not clear the point.
MichaƂ wrote 04/26/2021 at 00:00 point
You can create metal composites of any topology and internal structure. In easy and cheap way.
dekutree64 wrote 04/19/2021 at 01:41 point
What sort of density compared to solid metal? Can you control the wall thickness? Can the inside foam be any size, or only a few mm like in the pictures? Does it only work in flat pieces, or could you make tubes with two thin walls separated by a layer of foam to increase stiffness, or even mold it in more complex/3D printed shapes? Does it only work in brass, or could you use aluminum?
MichaƂ wrote 04/19/2021 at 16:00 point
Thank you for these questions!
One of the samples had a density 1.2g/cm3, so like a rubber. But! I can't bend it in my hands...
In general - you can change all parameters of this structure as you like. Size doesn't matter. A 1cm or 1m item will be created at the same time.
You can use almost all metals, in any configuration, alloys etc.
Of course, it is possible to automate the process and use solutions known in 3D printing. However, I am working on a much more efficient method. The object will be created freely in space, without mechanical contact with the robot arm or the printer head.
dekutree64 wrote 04/20/2021 at 00:28 point
Sounds very useful! Are you planning to open source, patent, or take it to the grave?
