1Print instructions
Caution! This print requires parts to be inserted mid-print. These margins work for my printer but may differ for yours.
(I didn't use a multi color printer, in theory this should be possible for the base and frame. Let me know if you did!)
- First, print the base (top down for the best result).
- Then, slice the frame with a pause (or "color change") on 2.6 mm so that you can insert the base.
- Print the hangers with a pause (or "color change") on 1.8 mm so that you can insert the magnet.
Awesome Makes
