1Camera installation and test
Enable the Camera Interface
sudo raspi-config
Test camera
raspistill -o Desktop/image.jpg -w 500 -h 500
2Installation OpenCV
1.update raspbian and Increase the swap-size
sudo apt-get update && sudo apt-get upgrade && sudo rpi-update sudo nano /etc/dphys-swapfile #CONF_SWAPSIZE=100 CONF_SWAPSIZE=2048
2.Install tools and libraries for openCV
sudo apt-get install build-essential cmake pkg-config sudo apt-get install libjpeg-dev libtiff5-dev libjasper-dev libpng12-dev sudo apt-get install libavcodec-dev libavformat-dev libswscale-dev libv4l-dev sudo apt-get install libxvidcore-dev libx264-dev sudo apt-get install libgtk2.0-dev libgtk-3-dev sudo apt-get install libatlas-base-dev gfortran
3.Get source code
wget -O opencv.zip https://github.com/opencv/opencv/archive/4.1.0.zip wget -O opencv_contrib.zip https://github.com/opencv/opencv_contrib/archive/4.1.0.zip unzip opencv.zip unzip opencv_contrib.zip
4.Compile openCV
cd ~/opencv-4.1.0/ mkdir build cd build cmake -D CMAKE_BUILD_TYPE=RELEASE \ -D CMAKE_INSTALL_PREFIX=/usr/local \ -D INSTALL_PYTHON_EXAMPLES=ON \ -D OPENCV_EXTRA_MODULES_PATH=~/opencv_contrib-4.1.0/modules \ -D BUILD_EXAMPLES=ON ..
5.Build and Install openCV
make -j4 sudo make install && sudo ldconfig
3AMG8833 installation and test
- Pi 3V3 to sensor VIN
- Pi GND to sensor GND
- Pi SCL to sensor SCL
- Pi SDA to sensor SDA
1.Python Installation of AMG88xx Library
sudo pip3 install adafruit-circuitpython-amg88xx
2.Open i2c interface from Pi
sudo raspi-config
3.Interface Options--->I2C--->Enablesudo i2cdetect -y 1
4Install WiringPi Lib
1.Install wiringPi
sudo apt-get install git-core sudo apt-get update git clone git://git.drogon.net/wiringPi cd wiringPi ./build
2.check
gpio -v
5Run Final Code
mkdir build cd build cmake .. make ./face_detection
