Featuring mounts for the IVS 362 and the IPM 165C, with op amp circuits in the big white boxes with rounded corners. The IPM 165C has already been tested with oscilloscope and just needs the signal amplified for presentation to the ADC.The circuit schematic for the op amps is as below:
