So the screen I selected from Alibaba has a 18 pin 0.8mm pitch FFC connector, which after a few days of searching and calling a few connector manufactures, is almost impossible to source in quantities under about 3000. It includes a resistive touch screen but upon examination, it looks like there is a sizable air gap between the plastic viewport and the actual screen so I don't know if the screen will be able to be used. I'll explore that in the future though. Perhaps with a little creative dremeling, it's possible. The goal is to have to do as few modifications as possible on the case itself.
Just some hints. The screen you selected is supposed to be soldered directly onto PCB, instead of using a FFC connector. Resistive touch screen can be removed, or it's actually optional. I mean, you may order screen that without the touch screens.
Also, I think that it's impossible to use such a screen without mod the case, since the screen on sale use 4:3 aspect ratio while the original GBA screen use 3:2 aspect ratio. Maybe you can try to use original GBA screen (that 240*160 non-backlit tft screen)? To my knowledge, the original screen use a RGB TTL interface, which can be supported by RPi 0/1B+/2B/3, but I'm not sure about the compute module.
That's a good tip. That's eventually what I did. I made a little board I sent off to OSHPark's 0.8mm service that has the footprint. Right now it just turns right back into 1.0mm pitch connector since I didn't want to connect it directly to the screen but now I'm wondering if perhaps that's the best thing I can do.
I'll look into the original GBA screen but I think the challenge there would be sourcing them for cheaper than the 3.2" LCD (11$). My goal is to avoid destroying any original GBA's and providing a guide for people to build there own.
Actually, I'm also looking into mod GBA with a Raspberry Pi. Almost all the mod even the commercial GBA clone I see use 320*240 screen, which means it cannot be pixel perfect. Stretching algorithm would either make it blurred or somekind unbalanced. So I'm trying to find a 480*320 screen with the right size. 480*320 is 4 times of the original resolution, so it could be pixel perfect.
Oh that's a good point. Something I'm considering is the bezel is quite large and I don't want to modify it so I'm losing some pixels of the screen.
Most screens are SPI which has a reasonable refresh rate until you get larger screen sizes. I've been looking for screens that have a parallel interface but they're less common.
Thank you for the advice by the way! I forgot to mention that in my previous comment.
