New Panel Design
06/23/2021 at 15:57 • 0 commentsI made a new panel design which should be easier to use. It has a single 36-pin connector with 4 ground and 4 VCC pins. It moves the connector to the bottom of the card.
It should be easy to use white characters on black P-Touch labels to customize the LEDs and switches. The result should be like:
Jumpers, Switches, and Pushbuttons
06/23/2021 at 10:40 • 0 commentsMinimal Front Panel Design
LEDs via the LEDS-SWITCHES card.
- D4 = On while fetching instructions
- D3-D1 = SD card status
- D3
- on = SD card installed
- off = SDHC card installed
- D2 = Read from SD card
- D1 = Off when running, On when initialization is in progress
- D0= Off when running, On when initialization is in progress
- D3
Pushbuttons
- SW9 - Reset
Jumpers (J3)
- J3-1 to -3 - selects drive type
- J3-1 installed = RL
- J3-2 installed = RK
- J3-3 installed = RH
- J3-4 to J-6 = unused
