Hackaday.io Hackaday.io
Sign up Log in
Null Meter
Analog Null Meter/Differential Voltmeter
steve-tonerSteve Toner
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
4 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
529
2
4
3
Team (1)
  • steve-tonerSteve Toner
Join this project's team
hardware
ongoing project
analog
This project was created on 05/14/2021 and last updated 5 years ago.
Description
A proper analog null meter measuring down to 10 μV full scale.
Files
Schematic.pdf
Adobe Portable Document Format - 34.53 kB - 02/09/2023 at 01:59
Preview
Project Logs
Collapse
  • Null Meter Prototype
    Steve Toner • 05/14/2021 at 00:35 • 0 comments
View project log
Log In/Sign up to comment
Sign up with Github
OR
David Mason wrote 02/06/2023 at 21:48 • point
Steve, I just found your null Meter project.  I've started my own version of Conrad Hoffman's project, but I like yours a bit better because of the additional ranges and the differental meter function.  Would you share the project files, especially the PCB files.  I use Diptrace primarily, but also use Eagle.
Steve Toner wrote 02/09/2023 at 02:39 • point
I've uploaded a PDF of the schematic - as built.  As noted in the video, an additional resistor would be required for best accuracy on the 1V range, but that is not shown here.
I used ExpressPCB for this, so I don't think the PCB files would do you any good as they are in a proprietary format.
That's how I measured the pH with this lab grade DFRobot Gravity pH Sensor Kit V2
Project Owner Contributor
A Review to DFRobot Gravity pH Sensor Kit V2
sagar-001Sagar 001
Redesign analog bench meter with todays technology
Analog Bench Meter
sufSUF
LCR Meter
LCR Meter
yjmwxwxyjmwxwx
Now your FPGA-based retro computer can have its own mass storage too - just like it did circa 1980!
Cassette interface for FPGAs
zpekiczpekic
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Null Meter", please tell us the reason.
Send message
Remove Member
