Test code is working using the https://github.com/hrgraf/ESP32Wiimote Arduino library for one joystick. The direction and trigger buttons are working, responsiveness is great. But still not getting the paddle inputs on Super Break out. The 100k pot is always full left and 1M pot is always full right on the screen. Test code uses the WiiMote ± buttons to adjust the pot output. Resistance change looks fine with the multi-meter.
mulcmu
