Second PCB revision finished
05/18/2021 at 03:31 • 0 commentsFirst revision of the PCB was missing a trace. You can see it in the main project image. This has been fixed and I've assembled and tested the current version of the PCB. It's working fully, with the exception that the firmware does not properly animate the LEDs. This could be fixed in software, but I don't have the time or inclination at the moment.
Brian Barrett
