After getting the FPGA and PICO up and running it looks like I decided to flip the orientation of two of the displays on each display board. Fortunately I have an FPGA that is really good at single clock data remapping. A little bit of hacking in an inversion bit to the Chip Controller module in the FPGA and everything is better.
That is a lot of numbers......
