Just completed integration for code that enables the device to answer questions regarding moon phase and illumination. Now, when you ask the device a question regarding moon or phase, the LEDs will light up with a new cycling gradient effect, and the proportion of lights that are lit up will correspond with the phase of the moon.
Check out the code on our github!
Keerat Singh
