As things heat up on the #YGREC8 front, support of a binary format is essential. I have revived the archive and completed the revamp of the C ode, I must still work on the VHDL import, the JS code port as well...
There is now a git as well at https://gitlab.com/fhwd/HYX to follow the latest developments.
There will be several versions of the Y8's assembler so it is important to make them speak in the same voice.
Yann Guidon / YGDES
