YGREC8
A byte-wide stripped-down version of the YGREC16 architecture
YGREC can stand for many things, such as "YG's Relay Electric Computer", "Yann's Germanium and Relay Equipped Computers" or "YG's Ridiculous Electronic Contraption". You decide !
#YGREC16 is getting pretty large and moving away from the original #AMBAP inspiration, making it less likely to be implemented within my lifetime. So here is a "back to minimalism" version with
* 256 bytes of Data RAM (plus parity ?)
* 8 registers, 8 bits each (including PC)
* fewer relays/gates than the YGREC16
This core is so simple that I focus now on other issues, such as the debug/test access port, the register set's structure, I/O, power reduction...
Like the others, it's suitable for implementation with relays, transistors, SSI TTL, FPGA, ASIC, you name it (as long it uses boolean logic)!
After the explorations with #YGREC-РЭС15-bis, I reached several limits and I decided to scale it down as much as possible. And this one will be implemented both with relays and VHDL, since the YGREC8 is a great replacement for Microchip's PICs.
A significant reduction of the register set's size is required so I/O must be managed differently, through specific instructions. The register map is now:
  • D1  <= for NOP
  • A1
  • D2
  • A2
  • R1
  • R2
  • R3
  • PC  <= for INV
The instruction word is shrunk down to 16 bits. It is still reminiscent of the YGREC16 older brother but I had to make clear cuts... The YGREC8 is a 1R1W machine (like x86) instead of the RISCy YGREC16, to remove one field. Speed should be decent, with a pretty short critical datapath, and all the instructions execute in one clock cycle (except the LDCx instructions and computed writes to PC).
The fields have evolved with time (I have tried various locations and sizes). For example:
20171116: The latest evolution of the instruction format has added a 9-bits immediate field address for the I/O instructions.
20180112: Imm9 is now removed again...
20181024: changed the names of some fields
20181101: modified the conditions to change Imm3 into Imm4
20180112: Imm9 back again ! (for speed/latency reasons, no register operand is provided, an indirect IO register is used instead, and having more IO space is more desirable, otherwise only imm4 is available if a register operand is used)
There are 18 useful opcodes (as many as EDSAC plus INV, and the pseudo-opcodes HLT and NOP), and most share two instruction forms : either an IMM8 field, or a source & condition field. The source field can be a register or a short immediate field (4 bits only but essential for conditional short jumps or increments/decrements).
The main opcode field has 4 bits and the following values:
Logic group :
  • OR
  • XOR
  • AND
  • ANDN
Arithmetic group:
  • CMPU
  • CMPS
  • SUB
  • ADD
Deprecated:
Beware : There is no point to ADD 0, so ADD with short immediate (Imm4) will skip the value 0 and the range is now from -8 to -1 and +1 to +8. (see 17. Basic assembly programming idioms)
Shift group (optional)
  • SH/SA direction is sign of shift, I/R(bit9) is Logic/Arithmetic flag.
  • RO/RC direction is sign of shift, I/R(bit 9) allows carry to be rotated.
Control group:
The COND field has 3 bits (for Imm4) or 4 bits, more than YGREC16, so we can add more direct binary input signals. CALL is moved to the opcodes so one more code is available. All conditions can be negated so we have :
  • Always
  • C (Carry)
  • S (Sign, MSB)
  • Z (Zero, all bits cleared)
  • B0, B1, B2, B3 (for register-register form, we can select 4 bits to test from user-defined sources)
(notice the mnemotechnic trick: ACSZ are in alphabetical order)
Instruction code 0000h should map to NOP, and the NEVER condition, hence ALWAYS is coded as 1.
Instruction code FFFFh should map to INV, which traps or reboots the CPU (through the overlay mechanism): condition is implicitly ALWAYS because it's a IMM8 format.
Overall, it's still orthogonal and very simple to decode, despite the added complexity of dealing with 1R1W code.
This project is more than an ISA or one implementation : the goal is to become a platform. See log 82. Project organisation
Logs:
1. Honey, I forgot the MOV
2. Small progress
3. Breakpoints !
4. The YGREC debug system
5. YGREC in VHDL, ALU redesign
6. ALU in VHDL, day 2
7. Programming the YGREC8
8. And a shifter, and a register set...
9. I/O registers
10. Timer(s)
11. Structure update
12. Instruction cycle counter
13. First synthesis
14. Coloration syntaxique pour Nano
15. Assembly language and syntax
16. Inspect and control the core
18. Constant tables in program space
19. Trap/Interrupt vector table
20. Automated upload...
YGREC8_20231214.tbz
VHDL assembler works
x-bzip-compressed-tar - 205.14 kB - 12/14/2023 at 05:52
Download
YGREC8_20231012.tbz
The new wave of manuals. No source code yet.
x-bzip-compressed-tar - 141.32 kB - 10/12/2023 at 05:52
Download
YGREC8_VHDL.20211120-2.tgz
x-compressed-tar - 372.71 kB - 11/20/2021 at 14:46
Download
YGREC8_VHDL.20211120.tgz
x-compressed-tar - 372.09 kB - 11/20/2021 at 08:56
Download
YGREC8_VHDL.20211118.tgz
assembler refactored, supports DW and re-assembly
x-compressed-tar - 360.31 kB - 11/18/2021 at 17:29
Download
View all 60 files
  • Code Golf Snake: part deux
    Yann Guidon / YGDES • 12/17/2023 at 22:11 • 0 comments
    So far the last log brought us the following code:
    ; snake.y8
    ; in Bank 2 :
    .EQU last_choice 1
    .ORG 0
    ; init
    set last_choice A2
    set Right_Handler D2
    Top_Handler:
      set D1 D2
      set Select_direction PC
    Right_Handler:
      set D1 D2
    Bottom_Handler:
      set D1 D2
    Left_Handler:
      set D1 D2
    Select_direction:
      set last_choice A2
      in buttons R1 ; read the external state
      and 15 R1 ; mask only the relevant buttons
      set D2 PC IFZ ; jump to last choice if no button
      add (jump_table-1) R1
      LDCL R1 PC ; lookup and jump
    jump_table:
    ; .DW 0 ; 0000  => handled by the dispatcher
    .DW Top_Handler     ; 0001 (it's a priority encoder)
    .DW Right_Handler   ; 0010
    .DW Top_Handler     ; 0011
    .DW Bottom_Handler  ; 0100
    .DW Top_Handler     ; 0101
    .DW Right_Handler   ; 0110
    .DW Top_Handler     ; 0111
    .DW Left_Handler    ; 1000
    .DW Top_Handler     ; 1001
    .DW Right_Handler   ; 1010
    .DW Top_Handler     ; 1011
    .DW Bottom_Handler  ; 1100
    .DW Top_Handler     ; 1101
    .DW Right_Handler   ; 1110
    .DW Top_Handler     ; 1111
    This is where coordinates must be updated. I define the resolution of one of my flipdot boards: the 24×16 squares from Hannio.
    ; constants
    .EQU MAX_X 24
    .EQU MAX_Y 16
    ; variables' addresses:
    .EQU X_Head 2
    .EQU Y_Head 3
    .EQU X_Tail 4
    .EQU Y_Tail 5
    Since the lookup/jump table uses only one index, we can use A1 again to point at other things and preload the X and Y before the jump:
    Select_direction:
      set X_Head A1
      set D1 R2
      set Y_Head A1
      set D1 R3
      set last_choice A2
    And now that the "default" choice is handled individually, the jump table could be relocated and save one instruction in the loop. The very first, unused, entry can be a jump to the initialisation code.
    .ORG 0
      set init PC ; jump over the jumptable
    ; 0000 is already decoded
    init:
      set X_Head A1
      set (MAX_X/2) D1
      set Y_Head A1
      set (MAX_Y/2) D1
     The handlers can now be elaborated a bit:
    Top_Handler:
      SET ($+1) D1
      ADD -1 R3
      SET -1 PC IFC ; jump to failure if negative
    Right_Handler:
      set ($+1) D1
      ADD  1 R2
      CMPU (MAX_X-1) R2
      SET -1 PC IFC ; jump to failure if overflow
    Bottom_Handler:
      set ($+1) D1
      ADD  1 R3
      CMPU (MAX_Y-1) R2
    Left_Handler:
      set ($+1) D1
      ADD  -1 R2
    The address -1 in the code is a trampoline to the routine that handles the end of the game:
    Failure:
      ; play the defeat song here.
      HLT
    .ORG 255
      set Failure PC
    This way, the immediate address is short and the jump can be conditional, called from about anywhere at no cost. The addresses 0 to 7 are already allocated to the priority/jump table, but there are 7 more "short addresses" for trampolines to other routines.
    Now comes the big problem. The memory.
    There are only 256 bytes per bank and only 2 banks by default. To get things going, we assume the playground is only 16×16 sites so one site is one byte. This is enough to store the required information since this buffer does not directly represent the graphics (each dot is black or white, controlled externally).
    Each site needs to store the following information:
    • if the site is a "body" part (1 bit), and if so, the direction to the next one (2 bits)
    • if the site is a candy (another bit) (we can't represent a poison/trap with only 2 colors)
    That's 4 bits only out of 8 and we will see later how to compact them. Let's first lay out the logic and solve addressing later.
  • Code golf: Snake edition!
    Yann Guidon / YGDES • 12/17/2023 at 12:27 • 0 comments
    For this 150th log, the new assembler lets us put everything together and consider a larger program than the short examples we've seen so far. So it's time to implement this Snake game, at last!
    But it's also a sort of "code golf" for two reasons:
    1. there is not much space for code and data
    2. the code is expected to run on a very slow machine (the relay-based one, not onlu the FPGA)
    The relay machine is expected to reach maybe 20 to 30 IPS (instructions per second, yes) which leaves no headroom at all for a game loop, 20 instructions per loop for a 1Hz refresh rate. So that's maybe 30, maximum 64 instructions to store (or program on DIP switches). Yet the YGREC8 is not designed for the Ultimate Code Compactness of All.
    The first thing to determine is the direction. Already it becomes clear that the constraint of keeping the shortest possible execution time requires 4 separate code paths, otherwise there are many redundant or useless tests. So some duplication will appear but I don't think the size overhead will be significant, because there is more to do than steer the worm.
    Another part is about "drawing the snake". This is common with the 4 code paths. This can be reduced to two steps :
    1. draw the head
    2. erase the tail
    The head's new coordinates are given by the 4-parallel codepath discussed above. Removing the tail though requires storing the coordinates of all the X×Y previous positions, since eventually the snake could fill the whole screen. The required storage space gets too large. But there is a trick: the snake can only move to one of the 4 adjacent locations. This can be encoded in 2 bits.
    Managing the scoreboard is another task to consider. Managing the counters and updating the display will take "some cycles" for every iteration. I know because some time ago, I did this:
    https://scratch.mit.edu/projects/348604530/editor/my Snaique with MIT's Scratch.
    Not my best score, by far, but you get the idea.
    so some of the game mechanics is already conceptualised, except that here, the playground will be "black or white" dots. Or yellow, in the case of my flip dots.
    I don't know how many dots there will be but likely more than 16×16 and dot coordinates do not fit in a byte.
    The interface also includes 5 buttons (up, right, down, left, start/stop) and some sound (let's say the electromechanical chime)
    I explored the technical details at https://hackaday.io/project/20864-ygrec-15-bis/log/57054-tubular-bell.
    For the 5 buttons, let's simply say their state can be read directly off a GPIO port, mapped in the IO register space. Or, to make it even more handy, map the 4 direction buttons to the B0, B1, B2 and B3 conditions! The 4 buttons must first have a priority encoder then "remembers" the last choice, in case nothing is pressed. The "choice" can be stored as the address of one of the 4 direction handlers.
    The trick here is to use an address register to index the table of entry points, save the index when a choice is taken, and restore the last valid index in case no new choice appears.
    ; First draft for the direction decoder
    ; in bank 1:
    .EQU jump_table 1
    ; indices 1 to 4 store the values of Top_Handler,
    ; Right_Handler, Bottom_Handler and Left_Handler
    ; in Bank 2 :
    .EQU last_choice 1
    .ORG 0
    ; init the jump table
    set jump_table A1
    set Top_Handler D1
    add 1 A1
    set Right_Handler D1
    add 1 A1
    set Bottom_Handler D1
    add 1 A1
    set Left_Handler D1
    set last_choice A2
    Top_Handler:
      set D1 D2 ; save the choice
      set Select_direction PC ; or somewhere else
    Right_Handler:
    Bottom_Handler:
    Left_Handler:
    Select_direction:
      set last_choice A2
      set jump_table A1
      set D1 PC IF0
      add 1 A1
      set D1 PC IF1
      add 1 A1
      set D1 PC IF2
      add 1 A1
      set D1 PC IF3
      set D2 PC ; default/old value
    The priority...
  • Assembler v2023!
    Yann Guidon / YGDES • 12/14/2023 at 05:51 • 0 comments
    A new breed of assembler is now ready in VHDL. Lionel makes his own in bison+flex, which might lag somewhat, but at least there is a functional command-line tool that eats .Y8 files and generates anotated .HYX dumps, along with optional dumps of the symbol table.
    Here is one of the example code samples that pass easily:
    ; ygrec8/y8/asm.y8/gPEAC.y8
    ; created by sam. 11 nov. 2023 19:24:01 CET whygee@f-cpu.org
    ; version sam. 16 déc. 2023 21:34:37 CET
    ; gPEAC perfect moduli < 256/2 (no overflow of byte):
    ; 2 6 10 26 30 38 50 66 86 114 126
    ; orbit length is mod^2 + mod
    .EQU MOD 10 ; Modulus
    .EQU ITERATIONS (MOD * (MOD+1))
    .ORG 0 ; default start value
    SET MOD A1; mod (110 iterations)
    SET ITERATIONS A2 ; loop counter
    SET 1 R1 ; X
    SET 0 R2 ; Y
    SET 0 R3 ; T
    ADD R2 R2 ; 0+0=0 : clear the Carry flag
    reloop:
    ; first step
    PF R2 IFC ; copy carry flag to carry in
    ADD R1 R2
    SET A1 R3
    SUB R2 R3
    SET R3 R2 IFC ; modulo
    ; second step
    PF R1 IFC
    ADD R2 R1
    ADD -2 A2
    OVL -1 IFS ; exit when loop counter expired
    SET A1 R3
    SUB R1 R3
    SET R3 R1 IFC ; modulo
    SET reloop PC
    This is the result:
    $ ./vasmy8 "-gfinput=../../asm.y8/gPEAC.y8"  "-gdump_symbols=1"
    :00 ; .ORG 0 ; default start value
    5188 ;l14: SET MOD A1; mod (110 iterations)
    738B ;l15: SET ITERATIONS A2 ; loop counter
    0C86 ;l16: SET 1 R1 ; X
    0586 ;l17: SET 0 R2 ; Y
    0686 ;l18: SET 0 R3 ; T
    2D72 ;l19: ADD R2 R2 ; 0+0=0 : clear the Carry flag
    85E2 ;l24: PF R2 IFC ; copy carry flag to carry in
    2572 ;l25: ADD R1 R2
    0E82 ;l27: SET A1 R3
    2E62 ;l28: SUB R2 R3
    B582 ;l29: SET R3 R2 IFC ; modulo
    84E2 ;l32: PF R1 IFC
    2C72 ;l33: ADD R2 R1
    7376 ;l35: ADD -2 A2
    7F97 ;l36: OVL -1 IFS ; exit when loop counter expired
    0E82 ;l38: SET A1 R3
    2662 ;l39: SUB R1 R3
    B482 ;l40: SET R3 R1 IFC ; modulo
    3786 ;l42: SET reloop PC
    ; SYMBOL TABLE DUMP:
    ; 'MOD' : user_symbol = 10 (x3)
    ; 'RELOOP' : address_symbol = 6 (x1)
    ; 'ITERATIONS' : user_symbol = 110 (x1)
    ; 'VASMY8_VERSION' : user_symbol = 20231212 (x0)
    This is a 1.5 pass assembler: Lines where a symbol is undefined get stored for later and are re-assembled at the end. This creates a .HYX where a sequence of .ORG in reverse order are dumped at the end, which stretches a bit the format's convention but it's not an issue if the file is fed into a tool that will reorder the values (such as the upcoming simulator).
    With such a tool, a major milestone is reached: it is now possible to write and assemble larger chunks of code and even whole programs, not just small examples. I'm thinking about the Snake program. This allows a better evaluation of the balance of the instruction set, and eventually adapt it.
    The snapshots are as usual on gitlab and this one is also mirrored here at YGREC8_20231214.tbz
    The doc must be extended and completed but I'm almost ready for the next milestone: the simulator. Which raises a lot of new questions about its structure and organisation, in particular the interfaces.
  • Opcode space statistics
    Yann Guidon / YGDES • 11/20/2023 at 17:53 • 0 comments
    The new VHDL disassembler is here !
    And the dumb testbench is a great opportunity to collect numbers and figures.
    [ASM]$ grep '[;]' all_opcodes.log |wc -l
    11008
    [ASM]$ grep 'INV' all_opcodes.log |wc -l
    14720
    This means that among the 65536 possible instructions, 22% may be re-attributed later, but more importantly, this disassembler provides a clearer picture of how the decoder will work later to detect invalid opcodes.
    The INV opcode only accounts for 4096 instances, and the reserved opcode 1011 has 4096 more. That's 8192 so far. Oh and there are unused opcodes in the 1010 range.
    The above count also includes all the undefined PF fields, as well as some unused bits in the extended opcode range. All those "holes" in the opcode map are flagged with a comment so they can be conveniently tallied.
    I have also seen that the CALL imm4 instructions look quite dumb but you never know, some "negative addresses" might be trampolines for functions later, and these short forms allow conditional execution. This proves that "going with the architecture", instead of following the quantitative approach of Patterson & Hennessy, can give rise to new coding patterns, structures and interesting techniques.
    Vive l'orthogonalité !
    And there is more redundancy :
    The assembler checks the immediate value first and if it fits in Imm4 (when applicable), promotes the instruction to Imm4cnd (for the 10 core opcodes). This means to for 10 opcodes, the range -8 to +7 of the Imm8 form is not used. This means 16*10 = 160 unused opcodes.
    Update !
    The new assembler forces Imm4 to be signed, but the disassembler generates a positive value so only values 0 to 7 are aliased between Imm4 and Imm8, 80 redundant opcodes only (though it still is 160 if the disassembler did output signed numbers and the program counts 640).
    The opcode scan identifies 15743 exceptions to the bijection rule. This includes redundancies, reserved opcodes and unaffected bits.
            diff := instruction_word xor instruction_assembled;
            if diff/="0000000000000000" then
              if
               not (diff ="0000111000000000" and i<38976) and --imm4-imm8 confusion for SRI=0..7
               not (diff ="0000000001000000" and instruction_word(15 downto 12)="1010") and -- reserved bit>
               not (i >= 41728 and i <= 41983) and -- reserved extended opcodes, RR
               not (i >= 42752 and i <= 45055) and -- reserved extended opcodes, IR and unused IR bits
               not (instruction_word(15 downto 12)="1011") and -- RSVD opcode
               not (instruction_word(15 downto 12)="1110" and     -- PF opcode
                    instruction_word(11 downto 10)                  -- IR, IR2
                  & instruction_word( 5 downto 3)/="00000") and     -- SRI
               not (instruction_word(15 downto 12)="1111")   -- reserved opcode
              then
                output_message(SLV_to_bin(diff) & "_");
                mismatch := mismatch+1;
              else
                exceptions := exceptions+1;
              end if;
            end if;
    The new scanner contains some logic that skips the invalid opcodes, which also doubles as a definition of invalid instructions for later.
        OPCODE=Op_RSVD
    or  OPCODE=Op_INV
    or (OPCODE=Op_PF and   -- PF opcode with IR or IR2 or SRI not cleared
          instruction_word(11 downto 10) & instruction_word( 5 downto 3) /= "00000")
    or (OPCODE=Op_EXT1 and
         (( instruction_word(11)='1' or instruction_word(9 downto 8)="11" )   -- 10 EXT1 reserved opcodes
      or  ( instruction_word(10)='0' and instruction_word(6)='1'))) -- unused bit when SRI
    The other exceptions are harmless issues of Imm4/Imm8 aliasing or NEVR condition.
    The logic complexity is reasonable.
  • System registers in the I/O Reg space
    Yann Guidon / YGDES • 11/19/2023 at 02:39 • 0 comments
    The project progresses a lot !
    The http://src.ygrec8.com/YGREC8/Manual/Y8-Manual.html is slowly getting more precise and pertinent thanks to help from @alcim.dev , Lionel and Kanna. The assembler is getting better but the simulator is the goal and it is obvious that certain core registers can't be accessed as usual, so they must be mapped to the IO registers space.
    I have been cautious to not overdefine or over-allocate this pristine area, so far, but now is the time to start somewhere.
    The basic model requires at least 4 8-bit registers:
    • Data RAM port 1 Bank (an 8-bit extension to the A1 register)
    • Data RAM port 2 Bank (extends the A2 register)
    • Current_Overlay (read-only, use the OVL opcode)
    • Flags (3) and Prefix (5)
    Since they uniquely define the whole CPU state, they need "shadow" versions that are automatically saved during an interrupt or exception/trap. That makes 4*2=8 addresses that are mapped in the "negative" addresses, when bit 8 is set:
    .EQU        A1BANK  -1 ; r/w
    .EQU        A2BANK  -2 ; r/w
    .EQU        CURROVL -3 ; ro
    .EQU        FLAGS   -4 ; rw
    .EQU SHADOW_A1BANK  -5 ; ro
    .EQU SHADOW_A2BANK  -6 ; ro
    .EQU SHADOW_CURROVL -7 ; ro
    .EQU SHADOW_FLAGS   -8 ; ro
    OK this doesn't seem practical because -8  falls outside of a 3-bit range (it amounts to 0). So let's offset things a bit with 7 other scratch registers, used to spill and/or save an interrupted state:
    .EQU SCRATCH_A1     -1h ; r/w
    .EQU SCRATCH_A2     -2h ; r/w
    .EQU SCRATCH_R1     -3h ; r/w
    .EQU SCRATCH_R2     -4h ; r/w
    .EQU SCRATCH_R3     -5h ; r/w
    .EQU SCRATCH        -6h ; r/w
    .EQU        A1BANK  -7h ; r/w
    .EQU        A2BANK  -8h ; r/w
    .EQU        FLAGS   -Ah ; r/w
    .EQU        CURROVL -9h ; ro (use the OVL opcode)
    .EQU SHADOW_PC      -Bh ; ro
    .EQU SHADOW_A1BANK  -Ch ; ro
    .EQU SHADOW_A2BANK  -Dh ; ro
    .EQU SHADOW_FLAGS   -Eh ; ro
    .EQU SHADOW_CURROVL -Fh ; ro
    This better version now includes a copy of the PC, as well as scratch registers that are used by a handler to save the state of a currently running program. One extra scratch register is provided, D1 and D2 are not saved because once you set the A1 and A2 registers, as well as the A1BANK and A2BANK registers, you can restore D1 and D2.
    9 registers are read-write (including the A1BANK, A2BANK and FLAGS), the other 6 are read-only (for now). During a context save cyle:
    A1BANK  => SHADOW_A1BANK
    A2BANK  => SHADOW_A2BANK
    FLAGS   => SHADOW_FLAGS
    CURROVL => SHADOW_CURROVL
    PC      => SHADOW_PC
    Maybe one day there will be an instruction or other method to restore the registers back from their shadow. Yet so far, only A1BANK, A2BANK, FLAGS and CURROVL are strictly required for a basic implementation.
    Beware : First restore  the AxBANK then only the Ax registers, to trigger a re-load of the Dx registers. Similarly, when changing the AxBANK, don't forget to update the Ax otherwise the Dx will contain data cached from writing to a different bank.
    We need other registers to provide more awareness and flexibility. For example, the cause of arriving at address 0 of an overlay:
    .EQU IO_A0CAUSE     -10h ; read, clear by writing 1s
    ; it's a bitfield:
    .EQU CAUSE_RESET         1h;
    .EQU CAUSE_OVL           2h;
    .EQU CAUSE_TRAP          4h;
    .EQU CAUSE_IRQ           8h;
    .EQU CAUSE_INV          10h;
    .EQU CAUSE_WATCHDOG     20h;
    .EQU CAUSE_DOUBLEFAULT  40h;
    .EQU CAUSE_OTHER        80h;
    Another convenient feature for later is to address the IO space in sequence. The address is 9 bits wide so there is a need for 2 byte registers for the address, one with 7 unused bits. The choice is different: take a data register for the one half of the addressing space, another register for the other half.
    .EQU IO_INDIRECT_PTR     -11h ; r/w, simple presetable counter
    .EQU IO_INDIRECT_SYS     -12h ; r/w
    .EQU IO_INDIRECT_USR     -13h ; r/w
    Now we also need to define what these extended condition bits test: let's just allocate one whole 8-bit register for each condition, which can control a multiplexer or whatever.
    .EQU IO_CONDITION_B0   -14h;
    .EQU IO_CONDITION_B1   -15h;
    .EQU IO_CONDITION_B2   -16h;
    .EQU IO_CONDITION_B3   -17h;
    The timers/counters will need much more registers than that, ...
  • Updated number syntax
    Yann Guidon / YGDES • 11/07/2023 at 14:24 • 0 comments
    Meeting Lionel helped discuss solutions, in particular the syntax of the assembler.
    Numbers are signed but in certain cases we need an unsigned number, I proposed this new syntax:
    [-+][0-9A-Fa-f]+[bBdDhHoO]?
    [0-9][0-9A-Fa-f]*[bBdDhHoO]?
    (if you speak regex and/or want to write a Flex parser)
    In short: a number is recognised by its first character, either a + or - or a decimal digit. The eventual suffix determines the base.
    The new feature is the "+" prefix that forces a positive number, which may exceed the limit for signed numbers. This is practical when using masks for example:
    AND +F0h D1
    OUT +511 A2
    This wouldn't work with the original syntax because F0h wraps around to the negative range and would throw an error. So what the + does is tweak the parser and assembler to transform the data into a negative number "internally" so it passes the requirements for a valid number.
    Screw it.
    It's too inconvenient to implement and use, in the end. So I'm back to the old convention used by the YASEP. Here is the new manual's description:
    • Numbers are recognised by their prefix: a minus sign or a decimal digit. They are by default written in decimal but can have an eventual suffix to specify the base:
      • d (decimal)
      • h (hexadecimal)
      • o (octal optional)
      • b (binary)
    • Each number must fit in the desired field. All numbers are considered signed but can be written using unsigned numbers for convenience.
      • Imm9 range: -256 to 511
      • Imm8 range: -128 to 255
      • Imm4 range: -8 to 15 (8 to 15 may output a warning)
      The user must be careful that the number is not sign-extended to an invalid value, in particular with Imm4.
    It should be clearer, easier to implement and use, but I'm disappointed it couldn't be better.
  • The status byte
    Yann Guidon / YGDES • 10/18/2023 at 03:33 • 0 comments
    The state of the YGREC8 core is represented by the A1, A2, R1, R2, R3 and PC registers, as well as the three Status flags C, S and Z. Of course, this excludes the memories (instructions and data) as well as all the I/O space registers (some could store bank numbers) but here I focus on the core.
    The three flags take three bits and that fits in a byte, with 5 bits left. With the new PF opcode, this free space is now totally used:
    • One bit is set when the current opcode of PF. This will be cleared by the next instruction, which will start by looking at this flag to modify its behaviour.
    • One bit will be new carry input, selected during the PF cycle by the condition field.
    • Three bits contain the real destination of the next instruction.
    1+1+3+the existing flags equals 8, it fits nicely.
    This matters not only for the simulator, but also because the core needs to handle interrupts and traps, which requires an accurate snapshot of the core that allows a precise restart.
    There are some unused fields in the PF instructions, which might require more bytes to be stored for the next instruction.
  • ENTRY: Another pseudo-instruction from CALL corner cases
    Yann Guidon / YGDES • 10/12/2023 at 05:12 • 0 comments
    What if you CALL using PC as SRI and another register as SND ?
    SND gets PC+1 but PC will get PC, which ... yeah it wil get stuck. So we can detect this special case.
    The result is that the next instruction's address will go into any other register, which is useful when starting a loop for example. So the corresponding opcode would be ENTER or ENTRY, useful when you don't want to compute addresses and your loop body has more than 8 instructions.
    set R1 42 ; some loop counter
    entry R2 ; sets R2 to PC+1
     ; do something long and useful here
      add -1 R1
      set R2 PC NZ
    ; end of loop
    This looks nicer than
    set $+1 R2
    Now this increases the pressure on the registers. You could put the address on the stack top for example, but the loop counter would be better suited for this location, as it can be implicitly saved when a call occurs.
    The address can be retrieved at the last moment:
    loopentry:
     ; do something long and stupid here
      set loopentry R2
      add -1 R1
      set R2 PC NZ
    ; end of loop
    The total code length is the same but the loop is slower by one instruction. It's not the highest code density ever, but it works.
  • System overview
    Yann Guidon / YGDES • 10/06/2023 at 22:44 • 0 comments
    A complete YGREC8 system requires more than the main datapath. The following diagram shows the other necessary blocks :
    The debug system is essential during development : this is the circuit that lets the developer write and read data inside the system. It can read and/or write :
    • the current instruction (read/write)
    • the result, SRI and SND (read only)
    • the flags (read only)
    • the current status of the core (read only)
    From there, the developer can inject arbitrary instructions to access the other parts of the system (memory blocks, I/O etc.), dump or modify the state of the system... The debug circuits are totally asynchronous from the main clock, usually significantly slower. The developer must stop the core when inspecting or writing data. It is a bit more intrusive than other debug systems but it is designed to use as few transistors as possible.
    The debug circuit has already been started as a standalone circuit but it could be replaced by anything that does the job, such as the Caravel harness used by eFabless (though it is much more complex and uses more real estate, meaning more prone to failure).
    The core should be able to work in "standalone" mode, when no host controls the debug circuits. This is usually controlled by the state of some pins during /RESET : the System FSM can wait for a debugger to take control, or the FSM can load external instructions, either passively (as a SPI slave) or actively (by reading from an external SPI Flash chip). If the Y8 system has no internal code storage, you can bootstrap the core by sending 512 bytes through SPI (with an Arduino, RPi or ESP). The System FSM also handles the RESET/LOAD/START/STEP/STOP commands received from the debugger.
    The Instruction FSM manages the lower-level details of scheduling the instructions and their details (such as OVL, HLT, LDCx, writes to PC...). This split of the FSM greatly simplifies the design and the modularity. More states are added as more features and corner cases are developed. Meanwhile, the System FSM remains core-agnostic.
    The Y8 core does most of the remaining work : decodes instructions, fetches operands, performs operations, write back the results and move things around... It reads instructions from the Instruction Register, which usually transparently interfaces the Instruction SRAM. The instruction can also be read or written by the debug circuit, for inspection, injection as well as for writing a new program or overlay into the Instruction SRAM.
    The Data SRAM is a plain memory array. 2 areas of 256 bytes each do the trick but some banking could take place if needed and if the necessary resources are available.
    The IO & Config Registers is a user-defined area of 512 bytes that does everything that the rest can't. This is usually where customisation takes place, signals enter or exit the system, default behaviours are configured...
    Still missing : the interrupt controller. Stay tuned.
  • More room for some opcodes
    Yann Guidon / YGDES • 10/02/2023 at 10:50 • 0 comments
    As I review and refresh the documentation, I realise that the pressure on the opcode map can be reduced a bit. There is a new prefix opcode (that interacts with the FSM)  but the extra/optional opcodes do not need the conditional/predication bits. This would move a whole block of opcodes to lower bits and free more room. The prefix would have its own opcode and INV will remain untouched. Some reorganisation is required as I refresh the doc...
    SH/SA/RO/RC are 4 optional opcodes that would now be located in the CND field, which is 3 bits wide. This leave 4 more opcodes, maybe for multiplication or whatever. But this frees 3 more main opcodes !
    Maybe LDCL and LDCH could have a 8-bit version though that would be pointless (a SET Imm8 Reg instruction would do the same).
    IN and OUT would have their own main opcode root code, not straddling across bit boundaries
    Update :
    Here are the new versions of the opcode map and instruction format:
    There is now ample room for more opcodes in the future, though they do not seem required now. There is also a separate prefix opcode, a totally independent INV opcode, and IN and OUT have the same opcode binary prefix (unlike previously).
    The PFX opcode uses only the CND and SND fields, more could be used later. It doesn't check the I/R and I/R2 fields... yet. They should be kept cleared so far. More prefixes could appear in the future, for example using the SRI field.
    I know : this will force me to rewire the mechanical assembler... The VHDL assembler will also need some revamp.
    The core diagram has been updated too, implementing the prefix opcode: the output of the condition selector can be routed to the carry input of the ALU on the next cycle, and the writeback address can be delayed so write occurs on the register designated by the prefix and not the current instruction.
    Maybe later : CMPU & CMPS can be dropped by adding 2 flags to the prefix : one to prevent result writeback, another to treat operands as signed. This would enable tests using the boolean opcodes.
View all 151 project logs
Yann Guidon / YGDES wrote 11/10/2023 at 02:13 • point
TODO: LDCC selects the high/low byte with the carry flag for example
Yann Guidon / YGDES wrote 04/25/2021 at 21:57 • point
This project is not dead, I'm just extra over-busy with more immediate concerns and priorities...
salec wrote 10/09/2019 at 09:18 • point
YGREC can stand for so many things, but since my wife has been learning French on Duolingo I can't avoid noticing that it is also a wordplay on French spelling of "Y".
Yann Guidon / YGDES wrote 10/09/2019 at 10:03 • point
oh, of course, yes, too ;-)
salec wrote 10/09/2019 at 12:04 • point
always have an opening joke/tease for audience :D
Yann Guidon / YGDES wrote 10/09/2019 at 12:46 • point
@salec  always !
[deleted]
Yann Guidon / YGDES wrote 04/14/2019 at 08:56 • point
That "purposeful sense" may look drowned into the proliferation of projects, angles and ideas but it is still clear to me since it's my main hobby since 1998 at least :-D
I'm glad you enjoy !
Yann Guidon / YGDES wrote 11/04/2018 at 07:11 • point
Another note for later :
writing to A1 or A2 starts a fetch from RAM. In theory the latency is the same as instruction memory and one wait state would be introduced. However the processor can also write directly so the wait state would be only on read to the paired data register...
Yann Guidon / YGDES wrote 11/04/2018 at 06:55 • point
Note for later : don't forget the transparent latch on the destination register address field, for the (rare) case of LDCx, because the 2nd cycle doesn't preserve the opcode etc.
Yann Guidon / YGDES wrote 11/04/2018 at 07:18 • point
OK, not a transparent latch, but a DFF and a mux, plus some logic to control it.
-- DFF, every cycle :
SND_latched <= SND_field;
LDCx_flag <= '1' when (LDCx_flag='0' and opcode=opc_LDC and writeBack_enabled='1')   else '0';
-- MUX2 :
WriteAddress <= SND_latched when LDCx_flag = '1' else SND_field;
______
Note : LDCx into PC must work without wait state because it's connected directly to SRI, as an IMM8, and no extra delay is required. PC wait state is required for ADD/ROP2/SHL and IN.
Frank Buss wrote 10/27/2018 at 12:51 • point
Do you really plan 8 byte-wide registers? This would require thousands of relays :-)
Yann Guidon / YGDES wrote 10/27/2018 at 14:26 • point
no :-)
8 registers, 8 bits each = 64 storage bits.
1 relay per bit => 64 registers
The trick is to use the hysteretic mode of the relays :-)
Frank Buss wrote 10/27/2018 at 16:17 • point
Ok, makes sense. Maybe change the project description, someone might think you are planning a 64 bit architecture.
BTW, could this be parametrized for the address and data size? If you implement it in VHDL, you could use generics for this, would be no additional work to use just the generic names instead of hard coded numbers. Except maybe some work for extending the instruction opcodes.
Yann Guidon / YGDES wrote 10/27/2018 at 17:16 • point
Frank : DAMNIT you're right !
I updated the description...
Yann Guidon / YGDES wrote 10/27/2018 at 17:19 • point
For the parameterization : it doesn't make sense at this scale. Every fraction of bit counts and must be wisely allocated.
Larger architectures such at #YASEP Yet Another Small Embedded Processor  and #F-CPU  have much more headroom for this.
Bartosz wrote 11/08/2017 at 16:40 • point
this will working on epiphany or oHm or other cheap machine?
Yann Guidon / YGDES wrote 11/08/2017 at 18:07 • point
I'm preparing a version that would hopefully use less than half of a A3P060 FPGA, which is already the smallest of that family that can reasonably implement a microcontroller.
But it's a lot less fun than making one with hundreds of SPDT relays !
Bartosz wrote 11/14/2017 at 14:13 • point
Question is price and posibility to buy
Yann Guidon / YGDES wrote 11/14/2017 at 16:08 • point
@Bartosz : what do you want to buy ?
If you can simulate and/or synthesise VHDL, the source code is being developed and available for free, though I can't support all FPGA vendors.
If you want a ready-made FPGA board, that could be made too.
If you want relays, it's a bit more tricky ;-)
I have just enough RES15 to make my project and it might take a long while to succeed. There will be many PCB and other stuff.
However if, in the end, I see strong interest from potential buyers, I might make a cost-reduced version with easily-found minirelays. I don't remember well but the Chinese models I found cost around 1/2$ a piece. Factor in PCB and other costs and you get a very rough price estimate... It's not cheap, it's not power efficient, it's slow and won't compute useful stuff... But it certainly can make a crazy nice interactive display, when coupled with flip dots :-D
So the answer is : "it depends" :-D
