KT6368A is a dual-mode Bluetooth Transparent Transmission module that supports Bluetooth 5.1 version BLE and 2.1 version SPP function.
KT6368A transparent transmission test v1.0.pdfKT6368A transparent transmission test stepsAdobe Portable Document Format - 242.41 kB - 05/27/2021 at 03:20 |
aithinker_serial_tool_v1.2.3.zipPC serial toolx-zip-compressed - 118.38 kB - 05/27/2021 at 01:37 |
KT6368A Datasheet V1.0.pdfKT6368A DatasheetAdobe Portable Document Format - 511.98 kB - 05/27/2021 at 01:28 |
KT6368A AT Command en v1.0.pdfKT6368A AT CommandAdobe Portable Document Format - 214.80 kB - 05/22/2021 at 05:07 |
Is there a data sheet for the chip somewhere? A search didn't find it.
Q: can this chip transmit bluetooth audio signal to be received directly by a bluetooth earphones?
