The cables may have to go out opposing sides when 2 monitors are side by side.
Alignments were a lot worse because loctite superglue doesn't set as fast as hobby glue, but it still managed to clear the buttons.
The single latch was a disaster. It needs 2 latches in the corners, but that's where the magnets are.
The next task was displaying something useful, which would require native X11 programming because of the lack of clockcycles. Tiny confusers running native software are still better than buying a $4,000,000 room to fill with tower PC's just to run a different language.
