first_wristband.fcstdFreeCAD project file of the wristband add-on.x-extension-fcstd - 30.55 kB - 11/07/2016 at 03:31 |
ring.fcstdFreeCAD project file of the ring.x-extension-fcstd - 62.58 kB - 11/07/2016 at 03:29 |
first_wristband.stlThis is the STL file of the wristband part that goes into contact with the skin. It is suited for insertion in a replacement wristband for XiaoMi (for example there on Amazon: https://www.amazon.com/Colorful-Waterproof-Replacement-Wireless-Wristband/dp/B00VV7QGRM/ ). The small case is where the DS18B20 temperature sensor goes.sla - 114.93 kB - 11/07/2016 at 02:53 |
ring.stlThis is the STL file of a ring with a case for the temperature sensor DS18B20 (for small fingers: 15mm diameter)sla - 431.53 kB - 11/07/2016 at 02:51 |
