Hackaday.io Hackaday.io
Sign up Log in
Electrolytic polisher
A very useful device in the laboratory of dental prosthetics for the final processing of metal structures.
boboplBoboPL
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.7k views
0 comments
7 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
1.7k
0
7
11
Team (1)
  • boboplBoboPL
Join this project's team
completed project
hardware
Related lists
Featured Projects
Featured Projects on Hackaday.io
niceasome
nice things
This project was created on 05/25/2021 and last updated 5 years ago.
Description
3D printing made it possible to produce the most closely matched, necessary elements of a magnetic stirrer, adjustable rod clamps, ventilation ducts and a front panel frame inclined at an angle of 60 ° to the base plane for easy reading of displays.
Everything is enclosed in an extruded aluminum housing.
Smooth regulation of current intensity and step (encoder with button) regulation of working time in steps of 30 seconds, pause function, status LED indicator and sound signaling of the end of the process.
The anode is a polished piece and the cathode is a lead sheet formed into a cylinder. It can also be a copper sheet.
An 80mm fan works as a stirrer. 10x3mm magnets. The "jumping" stirrer in the jar contains 3 pcs of 4x4mm cylindrical magnets.
The pendant with alligator clips is connected to the power cord by means of a connector from an electric cube hidden in a printed clamp.
Details
Log In/Sign up to comment
Sign up with Github
OR
We want to stop the waste of energy made by cellphones by recharging it with a dynamo kit.
Project Owner Contributor
Dynamo Kit for Cellphones
asquare2masquare2m
This is a very original, effective, and interesting example of a safe lock.
Arduino Rotary encoder combination lock
mircemkmircemk
The 2016 Hackaday Prize
Love Risk, but hate constant dice rolling? With this device, there is no more inevitable dice falling off tables and knocking around armies.
Risk Battle Simulator
scott-clandininScott Clandinin
To improve response time, eye and hand coordination, I created a small gaming device.
Credit Card-sized Reaction Time game
gokuxgokux
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Electrolytic polisher", please tell us the reason.
Send message
Remove Member
