Putting it all together
07/16/2021 at 16:40 • 0 comments -
Creating the concrete mold
07/16/2021 at 14:21 • 0 commentsMy initial design used just 3d printed PLA to act as a concrete mold. While this was a good Idea I soon found out that Concrete and Grout Stick to everything and are difficult to separate. To remedy this I decided to go with making a silicone master mold.
To do this I start out with making a PLA version of the Knob with a PLA Ring to act as a mold box
Once printed I spray painted using several coats of High Fill Primer and sand the Knob down for a smooth finish.
I then poured Moldstar 30 Silicone into the cast. I waited 2 days for a full cure.
Once demoted simply pour concrete and wait 1 day for concrete to cure.
Boards Are in
07/02/2021 at 05:24 • 0 comments -
Concept
06/03/2021 at 04:21 • 0 commentsThe concept of Vo-LUM is to crate a HID Controller based of the Arduino Leonardo (Atmega32u4).
Goals1) Universally Control the Volume and Mute function on both Mac and PC (no Drivers)
2) Addressable LED to illuminate base of control knob.
3) Be hefty (Approximately 1-2 Pounds)
4) Completely USB Powered
5) Easy to duplicate and Program
//------------------Extended Goals-----------------
7) USB TypeC Interface
6) Integrate IMU / Compass for added functionality
