1Note
Make sure to follow the steps, Because it can save you a lot of time.
2Print The V-Slot adapters
Print the left and right V-slut adapters. you will need to use supports.
- 20% infill
- 2 Perimeters
- Tree support
3Print The Angle Makers
Print the left and right angle makers.
- 20% infill
- 2 Perimeters
- Tree support
4Print the T-Nuts if needed
If you don't have metal T-nuts, you can print them.
5Install The Adapters And Place The Angle Makers
Install The Adapters And Place The Angle Makers using T-nuts and M5 screws.
Put an M5 screw in the angle maker's smaller hole and mount it on the adapter. Now it should rotate around 40 degrees.
6Measure The Light Bar Length
For this, you may need to measure the back-to-back length of the angle makers when they're installed on the adapters (already on the printer obviously).
7Print The Light Bar
Open the light bar .stl in your slicer and correct the length of it (pay attention to only scale one axis, don't change the height and width). If your print bed is not big enough for printing it, you cant rotate it 45°, or if you dare, you can place it vertically.
8Print the Switch Box
- 20% infill
- 2 Perimeters
- Normal support if you need it for bridging
9Do The Electronics
Mount the switch and the barrel jack to the box and do the solderings. You know how to do it right?
but pay attention: you should disconnect the adaptors and the angle makers from the light bar before starting.
10Put Everything Together And Finish Up
Put the light bar, angle makers, adaptors, and the switch box together and connect them to the V-slots.
It's done!
setCREATE
