11[Build Instructions 4] 3D Design
I admit I've already drawn many 3D on Sketchup, but I really didn't know how to do this one... After some research, I went on a tube shape in which I drew circles. By deforming these circles I was able to arrive on the shape I was looking for. To adjust a dimension based on the center of the shape, simply hold down the ctrl key.
For the front, I just placed a flat face using the "Intersect Faces" option. Here is the result :
And here is the rendering on Sketchup with a little color and a lot more spines :
And ready to print with CURA (some spines are missing...)
12[Build Instructions 5] Prorotype
The tricky part here is tilting the HEADER 11 Pin by 15° so that the top PCB follows the slope of the hedgehog. I will try to design a small tool to facilitate this step.
As this is a prototype, there is a lot more connection here than there should be. I did a lot of tests...
All that remains is to make a small interconnection PCB. The prototype works well but lacks a bit of aesthetics with all its cables. -
13Bill Of Material
Here is an idea of the minimum and maximum manufacturing cost of the project (for one unit)
Component Quantity Total Price Teensy 3.2 1 19$ LCD 128x128 1 6$ TOF VL53L1X 1 9$ USB Micro 1 4$ BreadBoard / Wire / Header / 3D Print / LED 1 10$ Minimum Config total 48$ Replace LCD with a 240x240 1 12$ Relay 1 6$ Servo Motor 1 10$ Add TOF VL53L1X 2 18$ Maximum Config Total 82$
