Hackaday.io Hackaday.io
Sign up Log in
ATtiny814 NRF2USB
Simple development tool for wireless applications based on the NRF24L01+ 2.4GHz transceiver module and ATtiny814
stefan-wagnerStefan Wagner
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
5 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 1
View Gallery
432
1
5
6
Team (1)
  • stefan-wagnerStefan Wagner
Join this project's team
  • Project Files (EasyEDA)
  • Project Files (Github)
hardware
ongoing project
nrf24l01 wireless usb tinyavr attiny attiny814 UPDI arduino attiny204 attiny214 attiny404 attiny414 attiny804 attiny1604 attiny1614 pcb
This project was created on 06/05/2021 and last updated 2 years ago.
Description
NRF2USB is a simple development tool for wireless applications based on the NRF24L01+ 2.4GHz transceiver module. It provides a serial interface for communication with the module via USB. The CH330N (or CH340N) USB to serial chip can also function as a PyUPDI programmer for the integrated ATtiny814 (or compatible), so that no external programming device is necessary.
Details
Log In/Sign up to comment
Sign up with Github
OR
Rimit jain wrote 01/02/2023 at 17:19 • point
Hi is it like a normal usb drive which store a files and photo so we can share it through over the wifi ?
Module part of Apollo.IoT suitable for long-range GSM communications. The shield is equipped with a MicroSIM, 3.5mm jack and u.FL antenna
Project Owner Contributor
GSM communication module (GPRS, Voice, SMS)
vadim-raduVadim Radu
A compact module that lets you play RTTTL melodies with ease.
Programmable Music Module
dilshan-jayakodyDilshan Jayakody
Tear-down and Part Examination
TrackBall Module From Existing USB Devices
zvoddzvodd
Flexible, high-performance GPS receiver module
mPCIe GPS receiver
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ATtiny814 NRF2USB", please tell us the reason.
Send message
Remove Member
