A few different optical designs
06/23/2021 at 18:06 • 4 commentsI'm still trying a few designs to get more light output from the 3 Watt LED.
At least I've got the hang of building projectors with resin lenses that work right away. -
First ever holographic projection
06/18/2021 at 10:02 • 2 commentsThe flickering is due to the fact that my prototype runs on an Arduino Nano. The result is still amazing.
Then I can now turn my attention to the housing -
Prototype ready
06/16/2021 at 13:15 • 0 commentsPrototype is finished. Now I hope that everything works as I have imagined it.
First CAD Design of the UST-Projector
06/14/2021 at 13:04 • 0 commentsThis is the mirrorless version, for the projection tests.
Isn't that a crazy optical setup for a projector?
06/12/2021 at 12:04 • 0 commentsBut is seems to work. Next step, is the projection surface.
Very short projection distance, at maximum magnification.
The Projector Lens
06/11/2021 at 07:06 • 0 commentsI experimented with some loupes and VR lenses, but was not satisfied with the results.
So I tried epoxy resin. I managed (by accident) to make a lens with a focus point of a few mm. The first results with this lens are promising, even though it no longer covers the whole display and I can now only use 128x128 pixels. The distortion caused by this lens gives my hologram a special touch. I hope :)I held the lens directly in front of the eye and the camera directly on the other side. And the picture is not bad.
The Projector Part
06/08/2021 at 07:55 • 0 commentsFirst I develop the lighting for the LCD display. The display is an ST7735 chipset with a resolution of 128*160 pixels.
I use a 3W led as the light source. It should be bright enough for my project and will not generate too much heat during continuous operation.
I also need to make a pre-lens out of resin to focus the light onto the display.Here is the first test setup.
