In this episode, we are making the drum computer 3-channel polyphonic!
This requires some major rewrite and additional op-code side effect extensions. The 2x 16 registers obviously aren't enough for a 3-channel polyphonic 16 step sequencer, so we added some extra 3x16 array memory to the emulator. The registers R0 and R1 are used as index / address registers for the array memory. In fact, R0 would have been sufficient for 16 positions, but the array memory could be larger if I only had more SRAM available, at least conceptually ;-)
To work with the new array memory, I equipped a number of vacuous ANDI op-codes (3Fx) with extra side-effects to provide R0, R1 index increment, load from the array at the current index into Microtronic registers, and store Microtronic registers back into the array memory at the current index positions. Three registers are loaded / stored at the same time with one instruction (the array has shape 3x16).
Note that the official effect of the 3Fx op-code is to perform a bit-wise AND of 0xF with register x, which is idempotent for 4bit registers, so no program would ever use any of these 3Fx op-codes.
The new side-effects for ANDI with F are:
- 3F5: load array at location R0, R1 into R5, R6, R7
- 3F6: store R5, R6, R7 into array at index R0, R1
- 3F2: increment array index R0, R1 (to prevent boiler plate code)
Drum computer code:
# 3 voice polyphonic drum computer 00 022 01 3f1 02 f44 # r0, r1 are array memory index registers (currently, only r0 matters - 16 steps) # reset index to 00 03 101 04 100 # use r4 to display current index on display (copy from r0) 05 104 # load current array memory content at r0, r1 index into r5, r6, r7 06 3f5 # DIN input into rE - put HI on DIN 1, 2, 3 for channel select! 07 fde # channel 1? 08 91e 09 e0f # channel 2? 0a 92e 0b e14 # channel 3? 0c 94e 0d e17 0e c18 # input channel 1 -> non-blocking KIN into r5 # use NOPs so that all branches take equal number of clock cycles 0f ff5 10 f01 11 f01 12 f01 13 c18 # input channel 2 -> r6 14 ff6 15 f01 16 c18 # input channel 3 -> r7 17 ff7 # output r5, r6, r7 MIDI drum numbers to MIDI output 18 055 19 066 1a 077 # store current r5, r6, r7 values back into array memory 1b 3f6 # increment array memory index / address (r0, r1) 1c 3f2 # output r0 index to DOT 1d fe0 # copy r0 index to R4 so that we can see it on the display 1e 004 # loop 1f c06
Here is a video of the drum computer in action:
Michael Wessel
