1Step 1
The body is made of 3 layers of clear acrylic 6 mm each.
The middle layer host the LED strips and the square parts that diffuse the LEDs lights.
The plastic is cut using a CNC router. A V shaped drill bit is used to score the clear acrylic to diffuse the lights from the LEDS.
Est
