They say that an image is worth a thousand words, so let's have some images first!
This is an animated Gif that shows how the VVD looks when you walk around it, while it is showing a 3D model of the bones inside the foot.
This is another medical 3d model of a rib cage.
This 3D model is called "Palacio de Bellas Artes" By MiniWorld, on MyMiniFactory.
This is the most interesting Gif. A video has been recorded at 1000fps, and shows how the persistence of vision creates the illusion of a tridimensional shape.
The VVD projects the various horizontal layers of a 3D model on a special film vibrating very fast. This vibration of the image, exploit the "persistence of vision", a characteristic of our retina or brain, to retain an image after it has been removed, enabling us to perceive a whole object. This is believed to be the same principle of cinema animation techniques, where the viewer interprets a fast sequence of still images as a continuous moving image. This why this device is also called PoV (Persistence of Vision) volumetric display.
Madaeon
Joan Horvath
Moritz Walter
Maximiliano Palay
Olda
That's amazing. Does DLP need to be synchronized with the projection screen?
