Captains Log #13
05/02/2017 at 17:34 • 0 commentsAdded some Masterpiece Artwork
Captains Log #12
05/02/2017 at 17:05 • 0 commentsAdded Pi Prism Core PCB to Git hub link included
Captains Log #11
05/02/2017 at 06:24 • 0 commentsI changed the design of the PCB, next I'll label it and put some artwork on it.
Captains Log #10
05/01/2017 at 01:19 • 0 commentsThe designs still up for debate, the buttons will be moved to the side (soft tactile buttons). I will make a core pcb for the pi glass since finding the micro display varies for each person, currently I could shave a few mm off.
Captains log #9
04/23/2017 at 20:07 • 0 commentsCurrently drawing out a PCB design (a lot better than regular wires) resulting in a thinner pi glass.
Captains Log #7
12/18/2016 at 20:45 • 1 commentUpdated and building another Pi Prism and I still have some experimental printed optical lens from form labs (just need to sand it with very fine grit ) also I will experiment with a smaller camera.
After that ill add another branch which the Prism will be built on the Chip Pro which is smaller than the pi zero. Most likely based on the specs i might have to order a chip module and design a board around it ( ;-;).
Captains log #6
12/05/2016 at 18:46 • 0 comments![]()
updated the front stl (below)
Below I reduced the prism holder bridge to further improve viability
Scrapped the flexible button bridge in favor for a pla-flexible joint (To move the prism out of field view). Also a new smaller button bridge.
Integrated cover into the Pi cover stl (instead having a seperate loose cover)
Update will be pushed in a few hours as PiPrismV2
Captains log #5
12/05/2016 at 01:46 • 0 comments![Image result for thinking]()
Anyone that manages to connect a Bluetooth headset (microphone/speakers) to the Raspberry Pi post the stable solution below in the comments section. I wanted to use the bluetooth headphones for real time language translation to add on to the Pi Prism.
Here is some info I scraped up
Captains log #5
12/05/2016 at 01:12 • 0 commentsBluetooth Headset Blue tooth Microphone doesn't work http://youness.net/raspberry-pi/bluetooth-headset-raspberry-pi Bluetooth Keyboard/Mouse Combo Bluetooth keyboard issue
Ricardo Ferro
