I wired the socket for the microphone plus the neopixels.
![](https://cdn.hackaday.io/images/5631321625200529246.jpg)
The microphone bracket fit perfectly into the top part of the mouth piece.
![](https://cdn.hackaday.io/images/9805361625200509999.jpg)
The middle piece screw onto the top piece and holds the bracket in place.
![](https://cdn.hackaday.io/images/1012321625200489638.jpg)
I reattached the top/middle piece to the main phone part and everything fits perfectly.
![](https://cdn.hackaday.io/images/6882401625200472608.jpg)
With the mouthpiece cone screwed on you can't even tell there's anything special inside.
![](https://cdn.hackaday.io/images/2212731625200457373.jpg)
