- In order for the Projector to work with the raspberry Pi 4, I followed all the instructions provided by TI on their website, the explanations are quite clear and it uses a standard RaspiOS to work, with some python packages to install.
- I also used the RPiPlay project which installs an Airplay Server on the raspberry Pi in order to mirror the iPhone's screen : The installation is pretty straightforward and I had to rotate the image 90° in order for it to fill the entire display area.
https://github.com/FD-/RPiPlay
The lag between your actions on the phone and what is displayed on the projected image is quite acceptable for reading, and browsing images. I woudn't say so for videos or games.
hurðaskellir
aniketdhole
davedarko
ElecLab
