Phew, that was definitely the densest board I've routed. I was really close to simply running out of room and having to make it a 4 layer board and start over.
And here it is after removing one of the D's
So I was talking to [Stephan Bourgeois] who is working on his really cool MicroMaster Mini (seriously, take a second to look at that firmware, it's ridiculously good and I'm super jealous) and he thought it would be nice to be able to plug it in to breadWare and get the much higher performance protocol analysis and injection stuff you'd get from a dedicated piece of purpose-built hardware. So I threw in another 20-pin card-edge connector that allows them to both speak UART to each other and route signals anywhere so we can eventually add support for that.
Also, I had forgotten about the chip shortage for a while until I was buying parts for this, and it turns out the MCP2221A UART-USB bridge might be impossible to get, so I added a footprint for the FTDI FT231XS just in case. The FT231X apparently wants resistors on the data lines while the MCP2221A doesn't, so I made a resistor footprint with bridged pads so we can have the option depending on which one gets populated. So hopefully I'm now half as likely to get screwed over by chip availability.
This thing should just come with an xacto knife for how many solder jumpers there are.
Chip availability might also be a problem for the MCP4728 and MCP4661 but I decided I'm just going to hope for the best with those instead of covering the board in unpopulated footprints.
And it's not like I had a ton of extra room for that
But it's finished, now I just need to do the top board (which will definitely be 4-layers, so it should be a little easier if I can get my brain to intuitively switch between 4 layers without having to think about it.
I think the biggest obstacle to breadwares success is that it doesn't actually solve a problem. No one was complaining that they have to push wires into breadboard to make their circuits work. The online sharing of circuits is cool, but the user still has to install the chip and the caps/resistors. There are a couple of directions that come to mind that breadware could go. One would be incorporating the resistors and caps and make programmable resistors and caps so all the user has to do is plug in the chip. Another would be to make an intuitive serial interface with a battleship style selection grid and get rid of the notion of programming the board. I dunno, I really want to see this succeed because it's pretty cool, but you need to find a problem for this device to solve.
