Project uses my custom I/O Processor (IOP16). The I/O Processor is detailed here.
IOP16 Memory Map
There are three devices which are all memory mapped from the IOP16.
- 0X00 - UART (c/S) (r/w)
- 0X01 - UART (Data) (r/w)
- 0X02 - DISPLAY (c/S) (w)
- 0X03 - DISPLAY (Data) (w)
- 0X04 - KBD (c/S) (r)
- 0X05 - KBD (Data) (r)
I/O Device programming
All three resources have a 6850 style interface.
- The first location is the status value.
- The second location is the data value.
- The receive data present bit is the D0 bit and is '1' when data is present.
FPGA Resources
The memory resources can be reduced somewhat.
The character set can be reduced from 256 to 128 characters. This is controlled from the EXTENDED_CHARSET generic for the instance in the top.
-- ANSI Display -- Resource usage can be reduced by changing the generics below ANSIDisplay: entity work.ANSIDisplayVGA generic map ( EXTENDED_CHARSET => 0, -- 1 = 256 chars, 0 = 128 chars COLOUR_ATTS_ENABLED => 1, -- 1 = Color for each character, 0 = Color applied to whole display DEFAULT_ATT => "00001111", -- background iBGR | foreground iBGR (i=intensity) ANSI_DEFAULT_ATT => "00000111", -- background iBGR | foreground iBGR (i=intensity) SANS_SERIF_FONT => 0 -- 0 => use conventional CGA font, 1 => use san serif font )
The IOP16 code size can set from the IOP16 generic. For the ANSI terminal the code can be as small as 256 bytes. The EP4CE15 has 1KB blocks increments.
-- I/O Processor IOP16: ENTITY work.IOP16 generic map ( INST_SRAM_SIZE_PASS => 256 )
IOP Code
000 START 0x6004 IOR Reg0 IO_04 READ KBD STATUS 001 0x8001 ARI Reg0 0X01 MASK RX DATA PRESENT BIT 002 0xC003 BEZ SKIP1 NO KBD DATA 003 0x6005 IOR Reg0 IO_05 READ KBD DATA 004 0x7001 IOW Reg0 IO_01 WRITE TO UART DATA 005 SKIP1 0x6000 IOR Reg0 IO_00 READ UART STATUS 006 0x8001 ARI Reg0 0X01 MASK RX DATA PRESENT BIT 007 0xC003 BEZ SKIP2 NO UART DATA 008 0x6001 IOR Reg0 IO_01 READ UART DATA 009 0x7003 IOW Reg0 IO_03 WRITE OUT SCREEN 00a SKIP2 0xE000 JMP START
land-boards.com
Emach00
asraelvudogel
How do you think, is VHDL compared to Verilog is harder to learn?
