Hackaday.io Hackaday.io
Sign up Log in
ATtiny13A TinyPlayer
IR Remote Controlled MP3 Player based on ATtiny13A and DFPlayerMini
stefan-wagnerStefan Wagner
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
537
0
4
2
Team (1)
  • stefan-wagnerStefan Wagner
Join this project's team
  • Project Files (Github)
  • Project Files (EasyEDA)
completed project
hardware
attiny attiny13 ATtiny13a dfplayer mp3 audio ir avr arduino pcb
This project was created on 06/17/2021 and last updated 2 years ago.
Description
TinyPlayer is an IR remote controlled and LiPo battery powered MP3 player based on ATtiny13A and DFPlayerMini module. The DFPlayer module is controlled via a simple cycle-precise software implementation of the UART protocol (8N1, 9600 BAUD) in half-duplex mode. The volume last set as well as the track number last played are saved in the EEPROM and automatically loaded the next time it is started. TinyPlayer has a built-in battery charging circuit, which is supplied with power via a USB-C connector. You can directly connect a 3.7V LiPo battery and a 3W/4Ohm speaker to the board.
Details
Log In/Sign up to comment
Sign up with Github
OR
A tiny LiPo charging module that can be used for adding portability to projects
Project Owner Contributor
uCharger
kaneKane
U3 is a FIO bootloader running at 3.3v. LIPO battery charger, battery regulator, NRF24 plug
U3 project from arduIoT .com
dimitri-synodinosDimitri Synodinos
World's first open source and modular phone kit
Seeedstudio RePhone: Fun & creative modular DIY sm
ediyeDIY
A simple setup page describing all the functions of ICStation's charger module and how to use them individually.
Dual USB Mobile Battery Charger Setup
electorialsElectorials
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ATtiny13A TinyPlayer", please tell us the reason.
Send message
Remove Member
