I began the project using an Adafruit FONA 3G board (#2687) and an Uno, following Adafruit's tutorial to learn about the FONA 3G and AT commands. Then replaced the Uno with an Adafruit Feather (#2771) for its smaller size and the ability to power both the FONA 3G and Feather with just one LiPo battery.
Adafruits small JST connector switch (#1863) is hidden behind the Trimline logo to power the Feather.
As far as how the phone operates, pressing the "hook" button gives you a dial tone (just like the "old days") for dialing, or allows you to answer the phone when ringing.
I also coded several "special" two-digit numbers. For example, dialing 92 sends the "AT+CREG?" command to the FONA. If "0,1" or "0,5" is the reply, the "service acquired" sound is played (AT+CPTONEEXT=62). Dialing 90 sends the “low/high” signal to the "Key" pin on the FONA to turn the FONA board off.
The pic in the middle shows where I mounted the parts inside the Trimline phone (note the battery has been moved to the side so that the Feather is visible). The speaker (#1891) is under the FONA and the microphone (#1935) is under the Feather.
Big thanks to all the folks at Adafruit for making these cool boards and having such helpful demos and tutorials on their products.
Also a big thanks to Justine Haupt for her website and all the build information she has posted there, it was very helpful to my completing this project.
That's just excellent! The Trimline was such an advance -- been meaning to write an article now for quite a while on the design process for the rotary dial, and how they managed to squeeze it down for the Trimline.
